Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Transmission Flush
Old Jul 18, 2004 | 08:42 AM
ove1's Avatar
ove1
Originally Posted by solidpwder
Well if they put the wrong fluid in and the tranny fails wouldn't they be responsible? They should know what there doing. Why would synthetic oil be bad? It out proforms other oils. I was tought synthetic oil is the best. I run AmsOil 5W-20 in my F-150 and the escape ( it cost about $45 each oil change) and I haven't had any problem with it.
But will they step up and accept responsibility if the transmission fails? And why on earth would you want to risk having YOUR vehicle out of service while the transmission is being rebuilt or replaced, even if it is still under warranty? What if it doesn't fail until after the warranty expires?
The dealer service department should know what they're doing, but there is a great deal of confusion due to the mislabeled dipsticks. Automatic transmissions are sensitive to the friction and flow characteristics of the fluid that they were calibrated to operate with. The wrong fluid characteristics can cause slippage and premature clutch failure. On my '01, both the dipstick and my owners manual specify Mercon. The manual also specifically states NOT Mercon V.
Old Jul 18, 2004 | 05:26 PM
solidpwder's Avatar
solidpwder
So i should tell ford to use regual mercon not mercon V
Old Jul 18, 2004 | 06:56 PM
ove1's Avatar
ove1
Bingo! My owners manual says Mercon, Ford P/N XT-2-QDX. The footnote says, among other things, that "Mercon and Mercon V are not interchangable" and "DO NOT mix Mercon and Mercon V." It's on page 251 of the '01 owners manual.
Also, if your dipstick says Mercon V, there is supposed to be a service bulletin instructing the dealer to grind off the V.
Old Jul 20, 2004 | 02:15 AM
Mojave2k's Avatar
Mojave2k
solidpwder.. Be sure to tell us what happened at the dealer.. I am sure your Amsoil synthetic is great for your engine, but the clutches in the Escape torque converter are set up for regular old fashioned Mercon.. I agree that synthetic is better in most applications but the CD4E trannie in the Escape is a earlys 90s design with some electronic upgrading for the shift points..We await an improved transmission from Ford...
Old Jul 20, 2004 | 04:28 PM
solidpwder's Avatar
solidpwder
Well I got the escape back from the dealer and what a differance. It shifts so much smother and better. On the recepict they say they use mercon 3.
Old Jul 21, 2004 | 01:18 AM
Mojave2k's Avatar
Mojave2k
Thumbs up
I suspect that is good old Dextron3/Mercon.. as we advised that should be used. As you can see they did not use the synthetic Mercon5... good for them.. you should have a smooth happy transmission..
Old Jul 24, 2004 | 08:45 PM
2fords2's Avatar
2fords2
I think that changing the tranny fluid is almost as easy as changing the engine oil on an Escape. I have an '01 Escape. To DIY, I removed the plastic shroud around the drivers side front wheel to get access to the radiator's return ATF cooler line to the transmission. Then I drained about 4 quarts from the transmission by removing the drain plug. Retightened the plug, and added back 4 quarts of fresh Motorcraft Mercon ATF. Then I disconnected and pulled the rubber hose off the return line to the transmission by the front wheel. Had my son start the engine and squirted about 2 quarts of old ATF into a clean jug. Added 2 quarts fresh fluid to the tranny. Then repeated the drain 2 quarts/refill 2 quarts cycle until I ended up using a total of 12 quarts of fresh ATF. Hardest part was removing and reattaching the wheel well plastic shroud. Cost? About $30 for the case of Mercon ATF that I bought at the Ford dealer. Since I measured the old fluid in a clear milk jug, I ended up adding back the exact same amount new fluid as old fluid that came out.
Old Jul 25, 2004 | 06:59 PM
solidpwder's Avatar
solidpwder
Could that be done on a truck with a removeabl pan and filter? just measure the fluid that came out on the pan and then do what you did on the radiator reture line?
Old Jul 25, 2004 | 08:34 PM
2fords2's Avatar
2fords2
Man, I'd think so, but it would depend on your make and transmission. You might want to check the FTE Tech Articles link in the upper right hand corner of this page. There is a pretty good "how to" article on transmission flushes. Look for: 07/06/2002 - Changing ATF Fluid in a E4OD and 4R100 Transmission - By Mark Kovalsky.
You may also want to read this Popular Mechanics article. It's fairly generic and uses the basic approach I described.
http://popularmechanics.com/automoti...mission_fluid/
Without a transmission pan drain bolt, I'd be certain you have a large enough container to catch all the old fluid as I suspect it is very easy to spill ATF prying open a corner of the pan.
Old Jul 25, 2004 | 10:02 PM
solidpwder's Avatar
solidpwder
Ya why is that why don't manufactures put drain plug on tran. pans for easy removel?
Old Jul 26, 2004 | 05:20 PM
tsdrallyer's Avatar
tsdrallyer
A flush is a good insurance value against failure in severe duty use as defined by the owner's manual. Use Mercon and only Mercon. No additives. Most Ford vehicles for some time now ... at least 8-10 years I think... have been designed with long life, cleanable, reuseable filters. They don't have to be changed every flush.
Old Jul 16, 2005 | 09:23 PM
hulkster2's Avatar
hulkster2
Smile
I'm of the understanding conventional MERCON, or synthetic MERCON may be used in the Escape. Motorcraft sells both.
MERCON V is a totally different formulation (not to be used in our Escapes), and I don't believe is provided by Motorcraft in a synthetic.
Old Jul 17, 2005 | 08:21 AM
  #28
bananaboat's Avatar
bananaboat
I believe Mercon V is a synthetic or possibly a semi-blend. I personally have stuck to plain Mercon/Dextron III due to the issues and not wanting to throw another variable into the mix. I'd be cautious of a plain Mercon synthetic blend unless you can find a TSB that states otherwise. Don't rely upon what a dealership might tell you unless they have a TSB in their hand. I've seen plenty of dealerships put Mercon V in the Escapes even though Ford has a TSB that states otherwise.
Old Jul 17, 2005 | 11:58 AM
  #29
hulkster2's Avatar
hulkster2
Question
All, this may seem like a dumb question, but do all Escapes w/auto (I have a 05 Escape Limited), use the CD4E tranny (I am reading much about)?
This is my first 'auto transaxle' vehicle, and as I look at the Ford (generic) Scheduled Maintenence Guide, it mentions the following trannys for 30K, or 60K fluid changes based on normal or severe service: Torqshift, 4R100, 4F50N, 4F27E.
The Service Guide states 'all others' as a fluid level check only every 30K.
Thanx
05 Escape Limited
02 Mustang GT
97 F150 Off Road XLT
97 Probe
95 Probe GT
Old Jul 17, 2005 | 09:37 PM
  #30
Bilbo's Avatar
Bilbo
Thing is, Escape V6 CD4E has a tranny drain plug on her tranny pan.
If you remove it with a 3/8" socket, it will drain 3.8 qts. Refill this with 3.8 qts of Mercon, run through gears and drain/fill 3.8 qts again, most of the trans fluid will be replaced. Some of the guys do this frequently, like every 15,000miles.
Again use Mercon/Dextron3 and NOT Mercon V
~Bilbo
