No spark...
The fuel pump pressurizes on key turn. I have had some intermittent spark at the coil, then it was gone. Coil resistances look appropriate with a digital ohmeter.
A light bulb on the tach side of the coil (tan wire) dims with the starter motor but I don't think it "flashes" on/off when I turn over the engine. This same wire has continuity to the distributed mounted module.
A friend told me that his buddy, with a similar truck had a problem with the coolant temp sensor being defective and telling the ECM not to fire... Any truth to that?
In KOEO mode, I pulled codes:
171, 179 (O2 faults)
327, 328 (EGR faults)
28 ("Loss of primary tach...?)
and some transmission-related codes.
Any ideas, anyone :-) Suggestion appreciated!!!
In your case, I more suspect that code 28 might indicate a TFI module failure. The one on the distributor. They commonly go out and the engine just drops dead. It's happened to me. Don't discount anything thought, modern EFI relies on all kinds of stuff working together correctly for the engine to run. It's possible for just one loose or corroded wire to stop you dead. Unusual, but it happens.
I've heard that there were historical problems with these "Thick Film" ignition systems. If defective, can they be replaced with a salvage unit or is only a new one recommended? (The truck is past its recall timeframe.)
