Aerostar Ford Aerostar
Which wheels fit?
Old Jul 13, 2004 | 08:03 AM
relmsta's Avatar
relmsta
Question Which wheels fit?
I have a '95 shorty and I am tired of replacing the hub caps that keep coming off due to the horrible road conditions in NY. I am thing I might want to go with a bigger rim than the 14 that is standard. Can anyone suggest a wheel that will fit the Aerostar? I do not want to alot of money but want a good buy for my money.
Please help!!
Old Jul 13, 2004 | 06:01 PM
MO51's Avatar
MO51
Different wheels?
I have a 96 XLT with the 14" stock aluminum wheels. The hubcaps are small things that stay on very well. Perhaps you'd consider just getting some of these wheels from the junkyard, and putting 225-70-14s on them. It gives you a wider tire, and they look better than the 215-75-14s. Plus, there's no adjustment needed to the speedo--the 225-70-14 has the same circumference, just doesn't look it.
Old Jul 13, 2004 | 06:30 PM
93nighthawk's Avatar
93nighthawk
I believe you can swap out any Explorer/Ranger rim (15" or 16") from the same era. I would just not go to big and remember to adjust the rubber size so you don't have to worry about clearnence issues.
Old Jul 13, 2004 | 06:41 PM
Beaned's Avatar
Beaned
I have a '97 shorty on that I installed 15" ranger rims with 215/65 15's. They look great. They have a deep dish effect. $35 apiece at a tire and rim place. Make sure they are the 6" and not the smaller 5.5" rims. They also will take small hubcaps if you want, but you need special lugnuts.
Good Luck,
Beaned
Old Jul 13, 2004 | 09:13 PM
PICKUP6772's Avatar
PICKUP6772
I just put a set of turbines from an '89 crown victoria on my wife's van, and they look great! I upgraded my tires to 225/70/15, and couldn't see throwing out perfectly good tires(75%), and rims. I sitll have turbines on the vic, i just found a cleaner set for it at a price i couldn't refuse (FREE!!!). The tires on my wife's van are now 215/70/15, and have no rubbing issues whatsoever. I just have to correct the speedo for the 5mph difference, but no big deal. They were a direct fit with no problems with the lugnuts.
Old Jul 13, 2004 | 09:20 PM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
I have seen an Aerostar with 17" Mustang rims, with the 245s? on it. Looked pretty neat.
Old Jul 13, 2004 | 10:02 PM
B-Aerostar's Avatar
B-Aerostar
I have Lincoln Mark 7 wheels on mine and they have the right offset and everything. 16 x 7 wheels with 225/60-16
Old Jul 13, 2004 | 11:03 PM
93nighthawk
Hhhmmm, if those will fit, then Slicers off of a 90-95 Taurus SHO would fit nicely, and match the 3.2L v6 SHO motor under the hood.
Old Jul 14, 2004 | 02:31 PM
428_cobra_man's Avatar
428_cobra_man
Talking
I bought a set of ranger mags for my van for 100.00$ they are 15" with 215 75 15 tires, I had nicer mags on it but I sold them when I got broadsided by an old lady backing out of her driveway (thought the van was going to be written off)I also still have the 4 stock aluminum Aerostar mags, 2 of which have snow tires mounted on them and the other two have spare tires on them I always keep a full-sized spare with me as i get flats at least once a week (Its used mostly as a delivery van and when driving on the side of the road you pick up alot of nails) but you could prob fit bigger tires if you chopped the fender wells, My only issue is that my front bumper scrapes the tire when i hit large bumps.
Swagtastic
Dec 24, 2011 08:05 AM
1990aerostar
Aerostar
Mar 31, 2006 10:11 AM
nightshifter
Aerostar
Oct 24, 2005 01:51 AM
focusyn
Aerostar
Apr 23, 2005 07:15 PM
