4x4 road noise
Old Jul 12, 2004 | 05:10 PM
djdownie's Avatar
djdownie
Question 4x4 road noise
I accidently put my 2000 Expedition in 4 wheel high on dry pavement and now it sounds as if it is stuck in 4 wheel drive. It drives O.K. and the milage is not affected but it just whines loudly. It seems to go away at expressway speeds. Any comments or help would be appreciated.
Old Jul 13, 2004 | 08:50 PM
High_Horse's Avatar
High_Horse
If it was engaged your 4x4 light should be on. I would run through the gears sitting still on the four wheel, set back to 2 high, back up about 15-20 ft, then try driving regular. If you are engaged somehow in 2 high, usually backing up will disengage the system.
Old Jul 13, 2004 | 09:29 PM
PaulC's Avatar
PaulC
Try to make a tight low speed turn on pavement. If you're in 4HI, you'll feel a great deal of pulling and vibration through the steering wheel and the vehicle will significantly slow down.
1DCRANGER
1983 - 2012 Ranger & B-Series
Jan 4, 2014 03:55 PM
MER
Mar 8, 2008 09:28 PM
john atchison
Sep 27, 2005 11:41 PM
merv1
May 26, 2003 12:26 AM
Citoriplus
Offroad & 4x4
20
Mar 15, 2002 08:08 PM
