What speed do you intend to average? What kind of terrain will you be traveling over? Between the truck, probable cargo, and the trailer, you'll probably be moving 10,000 - 10,500 lbs. down the highway. That makes me want to stay away from O/D in order to prevent lugging the engine.
These trucks were made to tow. Use the OD untill it starts "hunting" for the right gear then turn it off. When you are past whatever made it hunt, shift back to OD.
You aren't going to hurt it.
Don't use O/D when towing for any reason especially w an auto-the amount of shifting your tranny will do between O/D and D isn't exactly "good for it."
Scott
Scott
I think that it all depends... are you talking just the Expy or all vehicles?
My wife has an 03 Expy EB, have not towed anything with IT cause that is what I have my truck for (02 F-250 PSD). My truck it stays in OD.
There is no reason not to use OD unless the truck keeps hunting for gears (down shift, up shift, down shift, etc.) if it is doing that lock OD out. If not leave it in OD.
Well, the only vehicle I own that is tow-worthy and has O/D is my explorer, which I tow my boat with. It shifts like a mother if left in O/D. All of my tow-worthy trucks are 4 or 5 speed or C6(no O/D), so I couldn't give an experienced based opinion on them, but the dealer at which I bought my boat suggested not to drive with any automatic in O/D.
Scott
Well.... Ford says it's OK to tow in OD.
Sounds to me like the boat you are towing is too heavy for your Explorer.
I had a Ranger pick up that I used to tow with & always towed in OD. It had almost 300,000 miles on it when I gave it to my kid. Never a problem.
Used OD in my Aerostar , a couple F150's & my F250. Never a problem related to towing. All ended up with over 200,000 miles on them.
Current Aerostar (94/180,000 Mi), F-250(97/290,000Mi) & Expid (99/136,000Mi.) No problems with trans.
Locking out OD will not hurt your truck. Just run at higher RPM's & use more fuel.
I towed a liteweight 19' bassboat with my 01 explorer and it hunted all the time unless I locked it out...Upgraded to the 03 Expy, towed to SanT South Carolina and back (~1100miles round trip) and only took it out of OD when in small towns, off of the interstate...Maybe a total of 50 miles on the trip out of OD..And no problems running 70-75 in OD up I95 and back...
Good thought there- the guys who build em oughtta now the reason for not using O/D better than any of us can explain- so I'd recommend doing as they say, but afterall, it's your drivetrain so do with it as you will....
Scott
AAMCO "Leave it in OD, it knows where it needs to be. If it's changing constantly leave OD off."
Real Life Observations
Lowere operating temps when towing in OD.
Removed trans pan for filter/fluid change. Obsolutley no sign of trans issues. Fluid was great after 3 years of towing #5000 trailer.
