General Automotive Discussion
Duplicate Keys
Old Jul 12, 2004 | 02:09 PM
DBush's Avatar
DBush
Duplicate Keys
Does any one have any other options besides going though my dealer to get dup keys made. I only have the one that came with my used excursion. The dealer wants over $100 to get one programed.
Old Jul 12, 2004 | 02:41 PM
alittle40's Avatar
alittle40
Try a locksmith. They usually have a Look-a-like PATS key blank that is 40 percent cheaper than the dealer and can be programmed at less than the Dealer's $83.50 per hour Service rate.
Old Jul 12, 2004 | 02:47 PM
Bigles's Avatar
Bigles
Are you sure it is the programable key? My 04 F 250 is not the programable key. If not programable, try Wally World.
Old Jul 12, 2004 | 11:00 PM
Torque1st's Avatar
Torque1st
Posting Legend
I removed the antenna ring from around the lock and put the PATS key inside the ring secured with zip ties. Then I took the whole antenna ring and secured it with zip ties up under the dash. Now I can use a plain cut key to operate the vehicle. I don't have to have those keys with huge heads on my key ring either. Now I can have a key for all three members of the family and a spare for the wallet for $1.25 each.
Old Jul 13, 2004 | 05:51 AM
DBush's Avatar
DBush
Thanks for quick replys and the great ideas. Great idea with the zip ties Torque1st. Bigles do yo know how to tell if it is a programable key? I'll keep the lock smith in mind too alittle40.Thanks again for all your help.
Old Jul 13, 2004 | 06:07 AM
Bigles's Avatar
Bigles
The programable key looks like it has a thick plastic case snapped around the end. The regular key looks as if it was dipped in black plastic & stamped. It is thin on the end.
Go to a key cutting store & ask to see both. Compare the thickness of yours to them.
Don't know about other F 250's , but I was disappointed when I bought my Lariat and found that with the "advanced security group", you get the regular key and a non locking glove box. Guess that is part of Ford's thinking , that it is only a truck.
Good Luck!
Big Les
Old Jul 13, 2004 | 08:32 AM
Fordlover55's Avatar
Fordlover55
Still kicking!!
You can get the programmable key from Ford and program it yourself. Just have them cut it for you..to make them feel good. I read the instructions on how to do it somewhere...I think the manual that came with mine. I could be wrong there though, but I did read it. It's not that tough of a job to do.
Old Jul 13, 2004 | 12:47 PM
75Player's Avatar
75Player
You can program your own keys, BUT you have to have 2 programmed keys in order to do it. Otherwise the system won't allow programming of a new key. Thats why a new key from Ford costs so much. If you have both keys it should only cost about $18 for an extra key.
Old Jul 13, 2004 | 02:53 PM
another_ford's Avatar
another_ford
With my job I've used a locksmith a few times for various lost keys and Fords always cost me around $100 (programmed keys). For a non-programmed key around $50. If you can't tell if your's has the chip or not, just go to your local WalMart, hardware store, or whatever and have them cut you a non- key. If it works great! If not, then at least you have a spare in case you lock your keys in the truck.
Just be glad you don't drive a Mercedes (most of their newer keys are over five hundred).
Old Jul 13, 2004 | 02:59 PM
Bigles's Avatar
Bigles
I have been told, that using a "non key" in a programmed ignition will activate the anti theft mode, and the car will not start and will have to be reprogramed by the dealer. Can be costly.
Old Jul 13, 2004 | 03:33 PM
another_ford
In my experience that isn't correct, but maybe I've been lucky. I have had keys made before that myself and the locksmith thought were non-programmed keys only to find out that we needed one that was programmed. But once the new one was made, it worked fine. But like I said maybe I've been lucky.
