Sponsored by: Real Truck
Add A Leafs?
Old Jul 12, 2004 | 10:57 AM
viper69's Avatar
viper69
Add A Leafs?
I have an 2003 4x4 V8 5.4 F250 SD with the x-springs. I just purchased the Skyjacker 2.5 Add A Leafs for the front and rear. Can I use my factory U-Bolts or do I need new ones? Also if anyone has done this lift did you get 2.5"? More or less? I was also wondering about the Trax bar. Will I need a new one with this added height? I may even have to get the Skyjacker #' rear blocks to keep from being nose high. Any imput on this will be appreciated.
Old Jul 12, 2004 | 12:21 PM
tarscraper's Avatar
tarscraper
Viper,
Check out my gallery. I have the same truck. I have posted many questions on this topic if you want to search for it. I added a 2" Tuff Country add-a-leaf to the rear only. It sits almost exactly level now. Maybe a 1/2 inch or so higher in the backend. Without the add-a-leaf in the back end our trucks will squat like crazy with any load at all. Downright embarrasing till I fixed it.
I also have a 1 1/2" Tuff Country add-a-leaf for the front end sitting in the shed but I don't want to do it for fear of sending the truck nose high again. I may do it if I decide to change the rear blocks.
I would not put the add-a-leafs up front unless you also decide to replace the blocks in the backend. Well unless you like nose high. I do not think you will need to replace the Trax bar. I also did not "need" to replace my factory u-bolts. My truck was pretty new and not abused so I didn't feel the need to replace them. You will however hear from many people on the board telling you to do so, nothing wrong with that theory either.
I also replaced my shocks at the same time. Rancho 9000's, Rancho 5000 stabilizer.
Any questions let me know.
Old Jul 12, 2004 | 12:31 PM
etcetera's Avatar
etcetera
How do the X-springs ride? They are from the 450-550's right?
Old Jul 12, 2004 | 12:41 PM
tarscraper's Avatar
tarscraper
No they are standard with the plow prep package on any (well 99 on) super duty. They are fine if you like a firm ride. A little bit jouncy up front but not too bad. Much better once you ditch the OEM shocks.
Old Jul 12, 2004 | 01:26 PM
CAT_man_963's Avatar
CAT_man_963
My Dad just got a new truck with the x-springs and his truck rides exactly like my truck - I don't have x-springs but have added a 2" add-a-leaf. Not a bad ride - but it is a tad stiff - personally I like it - it seems to drive and handle turns a little better. I would think you'd get a pretty rough ride putting add-a-leafs under an X-spring but I could be wrong.
Old Jul 12, 2004 | 01:43 PM
tarscraper's Avatar
tarscraper
I agree with you CAT. I think putting the add-a-leafs up front on an x-spring could be a little too much. Especially with the 5.4L. Its pretty light as it is.
I keep looking at my front add-a-leafs in the shed wondering if I'll regret the install. I think I will let them sit there for awhile.
Old Jul 12, 2004 | 06:02 PM
brwolfjr's Avatar
brwolfjr
i have the tuff country add a leaf with the x springs and it is pretty stiff. I do clear 295's without a problem however.
Old Jul 13, 2004 | 02:24 PM
viper69's Avatar
viper69
Thanks for the imput. I am guessing that my ride will get stiff with the add a leafs and the x-springs but I guess I will find out. As far as being nose high my truck sits perfectly level right now so I was hoping that the add a leafs in the front and the back would still leave the truck level. I guess I could put on the Skyjacker 3" block if needed.
Old Jul 13, 2004 | 02:27 PM
brwolfjr's Avatar
brwolfjr
i have a 350 and my nose is still 1 inch lower - it is a great look
Old Jul 13, 2004 | 02:29 PM
brwolfjr's Avatar
brwolfjr
i have also been told never reuse u bolts. something about metal fatigue. i dont know the specifics.
Old Jul 13, 2004 | 02:35 PM
viper69's Avatar
viper69
I will probably get new U-bolts just to be safe. I have been running 295's with the x-springs. They fit great but when I put on the add a leafs I will probably go to the 315's....
Old Jul 13, 2004 | 07:59 PM
viper69's Avatar
viper69
If I find that the front add a leafs are to stiff does anyone know of a 2" or 2.5" hanger kit. Since I have the x-springs the 4" hanger will be too much. Thanx...
Old Jul 13, 2004 | 08:33 PM
Ford290's Avatar
Ford290
This link has hanger kits around 2"-2.5" from several different companies. http://www.rockymountainsusp.com/fd4_99f2_350.htm
I also have the x-springs and have been considering a 2" hanger kit, so if you put one on let us know how it works out!
Old Jul 14, 2004 | 08:42 AM
L-N-OR's Avatar
L-N-OR
My '01 F250 5.4L had "x" springs installed before I bought it to carry the plow weight. That's what I figure, because the truck is leveled out perfectly.
I just added Skyjacker AAL to the front and rear. It was exactly 2.5" f & r, check out my gallery. Note: when you get the AAL springs measure each one...my first (front) set was 5/8" different heights! Called Skyjacker they said shouldn't be. So I ordered another set...same thing. So I used the two (taller) springs, and sent the others back.
I used the stock U-Bolts. When torqued, the DS one is just the right length (couldn't be any shorter). The rest of them had plenty thread left.
I've found that when you torque the U-Bolts, they do stretch. However, if you keep the stress under the he yield strength, they can be used over and over. If you torque them past the yield strength, then you stretch them permanently, that's when I would replace them. Sometimes you can tell when the nuts won't thread on, because the stretching has changed the pitch of the threads on the U-bolts.
Exoptable
Mar 24, 2012 01:23 PM
archeat2
Jan 10, 2012 11:34 AM
FordTruckGirl77
Nov 11, 2008 09:07 PM
Night Bird
Apr 5, 2008 11:13 AM
jad4
Jun 14, 2005 09:42 PM
