New owner questions about steering problems
Hi I have an 04 psd 4x4 lariat. I have had a few strange problems that after researching the forums seem like others have as well. I was hoping to get some clear answers as to what the problem is and what the dealers did to repair it and any TSB # if possible.
My first problem is the steering bind at low speed or with my foot on the break people state its the hydroboost, p/s pump problem.
My second problem is the poping while pulling forward with the tires turned.
And my final problem is the excessive steering wheel play.
Thanks for any help.
on
I thought my steering had excessive play when I first got the Beast. Now 6,500 miles and a warranty alignmemt later I have no issues.
I came from a 2000 & 2002 F150 SC long bed FX4. 17" inch wheels but a wider, lower profile tire. The Beast certainly does not have the side wall height I was accustomed to. IMO taller, narrower tires take a little getting used to.
In my case I just had to get the alignment and get used to the new road sensations, so to speak. Handles great for me now.
I have seen a couple of handling complaints here @ FTE but not sure of the outcome. Except that some merely changed tires/wheels.
Sorry I can't help with the other issues as I have been fortunate not to experience them.
Others will be able to provide more input. FYI: Your vehicle & engine build dates are always helpful.
BTW: Welcome to FTE
BTW: Welcome to FTE
My second problem is the popping while pulling forward with the tires turned.
Check this site for TSBs http://www.intellidog.com/dieselmann/60bulletin.htm
Their is one (or two) in there about popping noises.
I too think it may be a 'I have to get used to it" issue...
the Ex has MUCH larger tires and MUCH more moving mass than anything else I had driven (save motorhomes) and it just took me bit to get used to the different feel of the vehicle...
and if 4 wheel drive, you have even more mass up front...
I too am just offering some opinion here since I've not felt I had any problems either !
My 04 F350 (harley edition) definitely wanders around. But my F150 did that too. I started wondering if it was just me and the way I drive,,,but last week I let my GF drive and she couldn't even keep it straight (which I have no problem now)
I did bring this to the service mangers attention and I was told that the 18" wheels and larger tires are partly responsible for this. My buddy who is very familiar with these things gave me his 2 cents,,,,,,,,,in a nutshell, the ford truck steering system is not as advanced as it could be. There seems to be a definite correlation between the sidewall of the tires, the pressure and the size too.
If this is all that will be wrong with my PSD, I'll live with it.
Best wishes,
Mark
Best wishes,
Mark
i to am having a slite problom with the steering, i somtimes hear poping on left hand turns while truck is moving almost a little thud under the driver floor only on left turns though. dealer looked it up in his special computer and said that it was a normal thing with the truck but in technical words i typed the whole post in before i will copy it and put it in here for giggles
THIS WAS A POST FROM A FEW WEEKS AGO MIGHT CLEAR SOME THINGS UP WITH STEERING NOISES
ok i went to my ford dealer today Maroone Ford of Fort Laurderdale FL. i stated my claim to them this afternoon and this was what happened. we test drove it and the service tech heard the noise. never heard of it before this was the first he heard of it. he put the VIN # into his computer serched HIS FMC site (Special site for techs) and it brought back the following information. Word for word
(Some 2003-2004 Superduty F-Series , Excursion and 2004 Econoline Vehicals with a 6.0L Engine and Torqshift Transmision may exhibit a clunk or pop on initial engagement from reverse to drive at approximately 2-3 MPH. This condition may be intermittent and is a CHARACTERISTIC OF THE POWER TRAIN MECHANICAL LASH. No repair attempts should be made)
Now that is direct word for word from their site of information for record i made the service manager print it out and give me a copy. he sent me on my way and i guess thats about all i can do.
You can find that service bulletin and more at http://www.intellidog.com/dieselmann/60bulletin.htm.
Please read the Guidelines for FTE and for each forum, you will post in.
