Which gear????
Old Jul 11, 2004 | 07:39 PM
fknipfer1's Avatar
fknipfer1
Which gear????
Just bought a 2002 F250 7.3L 4x2, strictly to tow with. Have a 9000# Keystone Montana. Trailer pulls heavy, with around 980#'s of tonque weight.
Noticed that at 60mph in OD I run around 1750 to 1800 rpm. I think the max torque on the 7.3L is at around 1600 to 1800 rpm.
Will the truck continually overshift into third gear or should I drive it in third gear. A lot louder engine noise in third than i overdrive or fourth. Have never pulled with a diesel so I don't know.
Towed a lot with a Ford V10 and generally had to keep it in third gear or at a 1 to 1 ratio.
Any ideas or comments welcome as at the end of July I am going to Arkansas for a week at the lakes and don't want to get the truck too hot or have problems.
Thanks ahead.
fknipfer1
Old Jul 11, 2004 | 09:31 PM
SoCalDesertRider's Avatar
SoCalDesertRider
Use overdrive on the flats. Going up hills, or if it starts shifting back and forth, run it in direct (3rd) and drop your speed some so you're not spinning the engine so fast.
