93 exp. sport air in hyd. clutch
Old 07-09-2002, 02:52 PM
llamar's Avatar
llamar
llamar is offline
I have checked around and can't find anyone that will give me a clue to why I keep getting air in my clutch system? Truck runs strong no clutch slipage,even with 140000mi. I bought it at 113000,so I don't know if it has been replaced. I have to bleed air out about once a week then it shifts great. I have a 91 ranger(130000)same system and no problem. How does air get in but no fluid leakage? Will I have to replace slave cyl. If I do I might as well do the whole works. Is there any o rings or seals that can be replaced(one guy told me he had to put a special o ring in input line) Thanks for your time larry:-X11
Old 07-13-2002, 12:38 PM
llamar's Avatar
llamar
llamar is offline
Hey come on guys give me a hand with this
Old 07-13-2002, 01:00 PM
fordinlinesix's Avatar
fordinlinesix
fordinlinesix is offline
I would say replace the slave cylinder. I had to do that on my '97 Explorer because I had to bleed the system every 3 or 4 days. Would work great after I bled it, but then it would get to where the pedal would feel loose and gears were getting harder to engage. I never saw any sign of leakage so maybe the seal was just going out when I replaced it.
Old 07-13-2002, 01:03 PM
fordinlinesix
The o-ring for the input line comes with a new slave cylinder kit. Go to Autozone and get a slave cylinder. Brakemaster is a pretty good brand, they're the only ones that makes brake equipment still for my '67.
Old 07-21-2002, 12:06 PM
llamar's Avatar
llamar
llamar is offline
Old 07-21-2002, 12:12 PM
llamar's Avatar
llamar
llamar is offline
Post 93 exp. sport air in hyd. clutch
opps I did that wrong. I thank the info. Kind of thought some way I will be replacing slave.I just can't get clutch to slip but might replace it to. Thanks again
Old 07-21-2002, 10:42 PM
GUALA's Avatar
GUALA
GUALA is offline
Kentpeg
32
12-16-2013 07:04 AM
robertother
22
01-02-2013 06:15 PM
renchr56
07-22-2010 07:04 AM
m_menosky
03-18-2010 08:37 PM
Quick Reply: 93 exp. sport air in hyd. clutch
