Fuel pressure regulator question???
One more thing, is to take it to your closest auto shop, and them help you out.
But first try the starting fluid
It seems like the injectors aren't opening when I try to start it with the pump on. But as soon as I disconnector the relay it fires right up and runs fine after I connect it back up. I'm thinking that this might be an electrical problem. Any Ideas?????
O and im just trying to help, soo sorry if none of my ideas are helping.
you're on the money.
relay have nothing to do with injectors.
I'm suspecting stuck open injectors which cause to dump excessive fuel.
If I were you I would stop immediately before you loses any more $$$.
you need to scan for codes to determine any faults codes. you'll need to borrow a scanner or have a knowledgeable friend to check out your EFI system.
by the way....please check the black wire that goes from harness to negative battery cable or post. That's your PCM ground. make sure the wires are not corroded, broken or whatever.
Like I said before and I'll said it again...."Don't assume it, just check it!"
When you start my truck, the starter will draw 7-8 amps, the PCM also requires about the same amperage. If my fuse link had previously heated up too high and partially burnt itself up then it won't be able to supply enough amps to power both the ignition system and the PCM. I have no proof of this, but it's the only thing that I can think of. If the PCM wasn't getting the proper amps it would not be able to tell the injectors when to pulse. I believe this is the case because the PCM appears to be working properly except for the initial start. If I had a PCM fault, then removing the fuel pump relay would not affect the start-up....but it does. I don't believe the injectors are getting a signal from the PCM at start-up because of a problem further back in the sequence. I believe that problem may be the fuse link, because both the starter and the starter selonoid are functioning properly.
Does anybody have any thoughts on this ??? (also, I do not believe running the codes will show anything, unless there is a fault in the pcm or fuel delivery system)
FYI..Injectors can be mechanically stuck open! When you remove the F.P. relay, no more fuel will be submit. Engine will runs when there's available fuel left inside the engine.
Always double check every electrical connections and clean them real good while you're at!
FYI.......Injectors fires when the PCM supplies the ground!
any good Tech will tell you that scanning the PCM for any codes can tell you something and can be easily pinpoint the problem.
FYI..PCM does not draw more than 2 amps . PCM gets it's pwer from EEC relay not the F.P relay
here's thing for you to check.
PCM pin # 40 and #60 goes to negative battery cable or post. They must be in excellent shape and clean. They're also part of injector ground!
PCM Pin #20 is case ground.
PCM pin # 37 and #57 is 12 volt power.
and check for 12 volt power to injectors. [ red wire] if no 12 volt power then trace the wire to PCM relay.
I doubt you got problem with pin #1 and #20 and #37 and #57 and 12 volt power to injectors.
if all above pins check out good, then couple things left.
mechanically stuck open injectors.
any one of the sensors isn't working properly.
clogged cat converter???????????????? [ it is possible since I only go by what you said! ]
defective PCM due to cold start strategy mode?
I've checked the PCM grounds and they are good. Your comment on the EEC is where I made my mistake. I must have traced the schematics wrong, because I believed that the Number one pin was power. I will double check on the grounds and do voltage checks on the other pins. I really appreciate your help Kwikford. I am sorry if I'm assuming things. I've been frustrated and have never tackled a problem like this before. I will check all thost connections and pins and see if I can get a code reader. I will post my results hopefully this weekend. Again, thanks for the help and your patience
1. I still think the problem is electrical because it is intermittent. The truck started up just fine 4 or 5 times in a row, then it would just crank and crank but not fire. Everytime I remove the fuel pump relay, it starts and continues to run if I put the relay back in. I have no idea why removing the fuel pump relay would allow the truck to fire. I've checked all the pcm grounds, as well as the grounds for the fuel pump and the grounds for the sensors. They are all good.
2. I've measured the voltage all the injectors and they are also good. So once again, I'm back at the same delima. I know I have good compression, but that cannot be intermittent. So I'm either not getting spark or not getting fuel. However, the fuel pump is ALWAYS pressurizing the system, and by testing the voltages dozens of times on the relay, it too is working fine. I've been continually testing for spark, and even when the truck won't start, I continue to have good spark.
3. Pin 40 and pin 60 on the pcm are both grounded properly. The PCM in general seems to be working fine because it consistanly lowers the voltage on the relay, so I know that the PCM is getting power at all times.
As far as the other tips go....I don't see how the injectors could be stuck open, because once again this is an intermittent problem and removing the fuel pump relay would not cause the injectors to start working properly. The fuel pressure will lower once the pump is inactive, but stuck open injectors wouldn't explain why the truck runs normally once the relay is put back in after start-up. I've checked the ECT sensor, MAP sensor, TPS sensor and O2 sensor, they all check out. As far as the cat. converter goes, I can't see a relationship between it and the fuel pump relay. If the converter was clogged then why would removing the relay cause the engine to start.
I know that one thing is true. Every time I pull out the relay, the truck starts up fine, and continues to run if I replug it back in. Therefore, I still think that this is an electrical problem and the problem lies somewhere between the wires in the relay and the rest of the ignition system.
I'm pulling my hair out with this problem and anymore tips would be appreciated. Somebody please tell me if I'm way off course here.
