Sponsored by: Auxito
Leaking rear window
Old Jul 10, 2004 | 09:05 AM
I LUV WI's Avatar
I LUV WI
Leaking rear window
99 F150 SC 4x4 5.4L
Sliding rear window leaks sometimes during/after a rain and going through the automatic car wash. Read many posts about changing the gasket. Could a person just run a bead of caulk above the window and solve the problem? Has anyone ever done this. I would think this would be cheaper and quicker solution to the problem.
Old Jul 11, 2004 | 02:14 AM
Racerguy's Avatar
Racerguy
I'm sure that would work but I do wonder if it could be done well enough to look good?
If it matters
Old Jul 11, 2004 | 01:21 PM
stantojl's Avatar
stantojl
Tried that on my before going thru with the real fix. Worked for a little bit and looked like crap.
Old Jul 11, 2004 | 03:49 PM
billybobzia's Avatar
billybobzia
i took the light assembly out (two screws) and caulked inside the light area really well and it fixed my leak (it was pretty bad)
