Computer Chips & Tuners
96 F 150 Chip?
Old Jul 9, 2004 | 10:14 PM
Fair 96's Avatar
Fair 96
Question 96 F 150 Chip?
Please excuse my lack of knowledge on this subject. My first real truck is a 79 F150, therefore you can see I need all the help I can get with newer technology..LOL..
I just got a 96 F 150 with a 302 Auto. and am wondering if there is a chip or something to increase engine performance in any way? What would work the best if more than one. Any suggestions appreciated...
Old Jul 10, 2004 | 12:29 AM
FTE Ken's Avatar
FTE Ken
Chip:
http://www.motorhaven.com/customer/p...6&cat=37&page=
Tuner:
http://www.motorhaven.com/customer/home.php?cat=169
Tuner offers the most features, chip the best power.
Old Jul 13, 2004 | 11:09 AM
Fair 96's Avatar
Fair 96
Thank you very much is the chip hard to install.. Or as easy as it looks?
Old Jul 14, 2004 | 09:26 AM
ssn randy's Avatar
ssn randy
the tuner also give the ability to read codes.
Old Jul 19, 2004 | 07:29 PM
FTE Ken's Avatar
FTE Ken
Chips take 15-45 minutes and require you to remove the computer box to install them. Tuners are extremely easy, you just plug them into the diagnostic port and follow the on-screen instructions.
Old Jul 19, 2004 | 08:41 PM
Fair 96's Avatar
Fair 96
Thanks again . Would it be possible to get the chip and the tuner or would it be overkill. Or do they work better by only useing one or the other.....
Old Jul 20, 2004 | 07:40 AM
ssn randy's Avatar
ssn randy
can't use both. the chip overrides any info on the pcm. the tuner is used to flash the pcm with the new info, using the chip would override the tuning.
Old Jul 20, 2004 | 11:15 AM
Fair 96's Avatar
Fair 96
Thanks that is greatly appreciated...
Old Jul 21, 2004 | 04:19 PM
ford5.8's Avatar
ford5.8
on the 96 I dont think you have to remove the computer,you can put it in with out doing that..
Old Jul 22, 2004 | 11:44 AM
ssn randy's Avatar
ssn randy
its under the kick panel on drivers side by the e-brake. never took mine out but some disassembly is required, its tight under there. get the tuner and save the hassle.
Old Jul 22, 2004 | 03:49 PM
Fair 96's Avatar
Fair 96
ssnRandy
I appreciate the location I was wondering where it was. I looked at your truck in your gallery and wow it is very nice. I noticed you had alot of bolt on Mods and I was wondering wich one gave you the most noticeable power increase. I was also wondering if you noticed much power difference after you put in the chip???
Thanks alot
Old Jul 22, 2004 | 05:01 PM
ssn randy's Avatar
ssn randy
the chip and yes it was the best money spent. it seems that after the chip everything came together and worked much better.
