1978 - 1996 Big Bronco
32's?
Old Jul 9, 2004 | 09:19 PM
rockinkcollins's Avatar
rockinkcollins
32's?
my 95 has the stock 31x10.5s on the stock chrome wheels. i want bigger more aggressive tires, but no lift or cutting. will 32x11.5's fit with NO rubbing?
im thinking swampers
Old Jul 9, 2004 | 09:29 PM
WhëëlMå1's Avatar
WhëëlMå1
32"s should fit, but swampers might get you in trouble. The lugs are larger than that of a standard tire, which will probably rub. One thing you can do is shim the bumper out a bit. That might give you a bit more clearance. One thing you might have to look at is backspacing. 32"s normally fit, but you might need to change rims to accomplish what you want. I am sure others will chime in here.
Rich
bronconorwood's Avatar
bronconorwood
They'll rub if you cut the wheels all the way. Really isn't a problem for me. I still have a really good turning radius. My 31x10.5's rubbed if I turned all the way too. No difference.
Old Jul 9, 2004 | 09:30 PM
bronconorwood
Oh yeah. I don't have Swampers. That may be a problem, I don't know.
Old Jul 9, 2004 | 09:35 PM
gumbyman38's Avatar
gumbyman38
there is a guy in here(cannot remember his name) who has 33's on stock rims!he has pics in his gallery proving it.maybe he will chime in .
Old Jul 9, 2004 | 09:42 PM
JBronco's Avatar
JBronco
Yeah 33's will fit but IMHO it looks stupid without a lift, and even 31's rub on full lock anyway with stock rims. And 33's with no lift will bottom out on hard bumps. 31's don't, not sure about 32's.
Old Jul 10, 2004 | 11:42 AM
rockinkcollins
i would like to keep the stock wheels too
Old Jul 10, 2004 | 03:45 PM
Nitro375's Avatar
Nitro375
Guys I have Cooper Discovers 32,11.50's on my 96 Bronco with no problems whatsoever on the factory alloys. Even had her twisted up pretty good a couple of times on washouts with no rubbing. Truck is stock.
Old Jul 10, 2004 | 06:52 PM
bronco5.8's Avatar
bronco5.8
I'm running Yokohama Geolandar A/T 32x11.50x15 on stock rims and stock height.
Warr
Old Jul 10, 2004 | 10:15 PM
bigric's Avatar
bigric
I'm running Bridgestone Dueler A/Ts 32x11.5s on stock 15x8 rims with no problems. The Bronco will take 33s on stock suspension without problem. I'm sure if you do a search you'll come up with about 20 other threads just like this one.
Old Jul 10, 2004 | 10:45 PM
gumbyman38's Avatar
gumbyman38
no,I saw this guys pics.he had his rig fully articulated.If I wasn't so lazy I know I could find them as it wasn't too long ago he posted.But since I AM lazy(hey babe!get me a beer!!!)
I dont' think I will find them.
Old Jul 10, 2004 | 11:24 PM
ryanguglich's Avatar
ryanguglich
Imho
My 88 Has 32x 10.5" All terrains and it rubs at full lock especially over bumps,
my 10.5's cut a bit on the front fenders if I'm really off-camber
my 81 had nearly bald 35's that rub less (on the frame and rad. arm) than my 32's buy they are on very offset rims and stickout the fenders, It looks great, but not to the police.
btw. there's no sheet metal in the way on my 81, the fenders are cut larger.
Old Jul 12, 2004 | 08:59 PM
willystyle21's Avatar
willystyle21
Got 32x11.50's BF MTTA's on mine. She runs well, only problem is when backing up and cutting hard. It begins to knuckle.
