Sway bar mounts
Old Jul 9, 2004 | 07:16 PM
cderalw's Avatar
cderalw
Sway bar mounts
Has anyone had a broken front sway bar mount. Front end shop says that it will take lots of time and money to remove the old one and install a new one so they suggest welding a new one to the frame, but I'm not real happy with that idea. Does anyone know of an after-market support bracket that bolts to the frame. If not I will spend the $$ to fix it right.
Old Jul 9, 2004 | 10:17 PM
MisterCMK's Avatar
MisterCMK
Did the end links break? Or did the sway bar, or control arm break? If it is just the end links, thats a 20 minute job per time.
Old Jul 10, 2004 | 06:13 AM
BigMan69's Avatar
BigMan69
If it is the end link, as mistercmk suggested, then go with an Energy Suspension end link kit. Cheaper than Ford's and much better quality. The end links are the long, maybe 8", bolts that the sway bar ends mount to.
BigMan69
Old Jul 10, 2004 | 08:01 AM
the4by4freek's Avatar
the4by4freek
If it is in fact the mount that goes to the frame, they sell them at Auto zone also. Energy suspension greaseable urethane mounts. About $20. If there is a broken bolt in the frame all you would need to do is drill a pilot hole in it and then back it out with an easy out. About a 30 min job total. I wouldn't recommend welding!
Old Jul 10, 2004 | 09:05 AM
myblkexpy's Avatar
myblkexpy
No matter which it is, I wouldn't classify it as "lots of time and money".
I advise you get under there and see what they're up to.
Old Jul 10, 2004 | 12:20 PM
cderalw's Avatar
cderalw
Thanks
Thank you for the info. Of course right after I posted, I figured out I did not really know which part of the swaybar system I needing to have fixed. When I can look at it I will fix it right w/o welding anything.
Thanks again
