Pneumatic reciprocating saw to remove rust?
Old Jul 9, 2004 | 10:01 AM
Indybroncoman's Avatar
Indybroncoman
I have to remove rust from my left rear quarter panel and am debating which tools to use. Hopefully you can help. Last night at Home Depot I was looking at a Husky pneumatic reciprocating saw. It can cut up to 5000 strokes per minute. Will this work or should I consider a different tool? Thanks in advance for any help.
Old Jul 9, 2004 | 06:42 PM
Aekisu's Avatar
Aekisu
<cr>
Well, your tool will work in most cases. The problem you may run into is if there isn't room for the saw blade to work.
I usually depend on a die grinder with a cut-off wheel.
Old Jul 9, 2004 | 09:07 PM
Scott Fraser's Avatar
Scott Fraser
I use a small air grinder with a thin grinding wheel and an air hammer with a sheetmetal chisel to cut out my rust. The recip saw will work given you don't start cutting through the inner panels in behind.
Old Jul 9, 2004 | 11:21 PM
MisterCMK's Avatar
MisterCMK
I second the vote for a cut off wheel. Mine worked great when fixing rust on an escort, and it will carve up pretty much everything in short order.
Old Jul 10, 2004 | 08:22 PM
Indybroncoman
Thanks guys, I'll go with the cutoff wheel.
roller_steve
15
Oct 21, 2023 09:33 AM
F1Jayhawk
38
Jun 23, 2011 10:22 AM
51dueller
23
Apr 6, 2006 11:20 PM
krankshaft
Aerostar
Dec 22, 2004 10:53 PM
Ken2600
Dec 25, 2002 09:17 PM
