Sponsored by: Auxito
Axle help?
Old Jul 8, 2004 | 02:18 PM
03Ford4by4's Avatar
03Ford4by4
Question Axle help?
WHile reading one of the posts, I became curious as to what gear ratio me rear end was. I went and looked on my door sticker and the axle code was 27. I have a 2003 F-150 4x4. The door sticker decoder said that i have a 3.31 non-LS and it also said that this ratio was only found in the F-250's. Is this a mistake? a misprint? I thought for sure that I would at least have 3.55's.
Old Jul 8, 2004 | 02:40 PM
krunker's Avatar
krunker
best way to tell is to look at the tag bolted to the diff cover.
Old Jul 8, 2004 | 10:55 PM
kspilkinton's Avatar
kspilkinton
The decoder is generic from '97 -'99, sometimes it doesn't seem to make sense with its explanations but it works for most '97-'03s F150s. Go ahead and look at your diff tag as krunker suggested, this is nearly fool proof as long as somebody hasn't swapped gears.
I'm fairly confident you have a 3.31 open rear with the code you have given because the factory did not change that code from '97-'03. The axle code also does not vary due to ring gear size, which is another reason to check the tag. Ex: you could have a 3.31 in either an 8.8 or a 9.75 rear. If you ever need a replacement part, you'd end up checking that tag anyhow. Key is the second row, the first "3" is usually burried under the bolt, it will then look like this: "31 8 8" or "31 9 75".
-Kerry
Old Jul 8, 2004 | 11:49 PM
03Ford4by4's Avatar
03Ford4by4
Kinda high geared eh?
It's been awhile since i've mesed around with gears and such (used to tinker in drag racing a lil') but, isn't a 3.31 gear ratio kinda high for a 4wd? I always thought that 3.55's or 3.73's came standard on 4wd's. Would love 4.11's though. I'll check the diff tag in the a.m. Thanks for your help!
Old Jul 9, 2004 | 12:40 AM
Racerguy's Avatar
Racerguy
Hi 03Ford4by4 and welcome to the forum
The shop manual does show a code 27 to be 3.31, non-limited slip in an F-150.
What engine do you have in your truck? Does the truck have many options?
Usually the trucks I see with gears like that are very basic and were ordered to be as cheap as possible.
Old Jul 9, 2004 | 09:46 AM
03Ford4by4's Avatar
03Ford4by4
Loaded
I have the 5.4L V8, leather interior, fog lights, CD changer, power everything (seats too), and a few other things. The truck is a 2003 which I bought used in May of this year (had 20k miles). If someone special ordered the truck.....what idiot would get such a high geared diff?
Old Jul 9, 2004 | 11:54 AM
Racerguy's Avatar
Racerguy
Yeah that is pretty strange.
I guess that whoever ordered it was more into looks than performance.
Old Jul 10, 2004 | 11:10 AM
kspilkinton
Perhaps the person knew about a pending gas price increase ? 3.31s would only give a slight increase in mileage in theory.
-Kerry
