fuel check valve
Old Jul 7, 2004 | 10:21 PM
bass4163's Avatar
bass4163
Question fuel check valve
had another post talking about fuel rail not holding pressure...was thinking,rather then drop fuel tank to replace fuel pump being the pump still works with motor running could i install a inline check valve to hold pressure in the rail for start up...also does the fuel in the main line return to tank passed the bad in-tank check valve on pump or by way of the return line to tank...would need to know which line to put the check valve on....thanks
