Alternator/voltage/idle problem
Have installed rebuilt alternator 3 times in last 2 months. First sign of trouble was alt/battery light on dash. Battery is clean and contacts good. All wire connections appear good. battery is showing full charge. Replaced alt and it was bad within 15 min of driving van. Got an exchange and it lasted about 1.5 months. Got an exchange and now I have new problems same day as alt was replaced.
While doing the last install I decided to replace the plugs and wires since it involved pulling everything that was already off. It was Sunday so I want to the local parts store and bought plugs and wires. When checking my handbook to verify spark gap it stated .52-.56 and also said use only awsf 42 pp plugs. It says that the 1-3 cyl get awsf 42 pg and the 4-6 cyl get awsf 42 p and not to interchange. Nobody I talk to has a clue about this and 4 different parts stores said just install the ones I bought (bousch platinum regapped to .52).
With that done I was driving the van and noticed that when the a/c (front and rear) is on and I make a stop the rpm drops slightly and the voltage appears to drop to around 10v (gauge goes from 8-18 with no scale in between). If the a\c is turned off then the voltage rises to about 13+/-. Also, if I take the car out of gear or idle it up while in gear the voltage returns to an acceptable range. The interior light also dims slightly when a/c is switched on. To double check I took the car to a parts store and they tested it with one of the portable testers. They said battery is good and alt is good.
I pulled the blowers and cleaned them which gave a little improvement.
I checked the voltage at the battery which is reading as follows:
Eng off 12.65v
Eng running out of gear no a/c 14.28v
Eng running out of gear a/c and fan on high 14.28v
Eng running in gear a/c and fan on high 12.60v (slowly
descending about .01 every 30 sec or so)
Eng running in gear a/c on high, front fan low, rear fan off 14.08v
A few things I noticed while working on the car while in gear and a/c running is that after 10 seconds of idle the rpm drops slightly. Still running smooth(doesnt sound like it will stall). At this point if I rap the throttle mechanism I get a small knock(1 time). Rpm goes up, a little slack in the response. If I rap the throttle while the rpm is up no knock or slack in response.
At idle there is a slight shake in the engine. Enough to see and feel but cant really hear a miss. There is a slight rythmic surge but not as frequent as the rmp.
In addition to plugs and wires I replaced air filter, pcv valve, and after noticing idle problem cleaned MAF, and air bypass valve.
I am also wondering if this engine may be different than what the parts stores have in their computers. I noticed that the firing order of my 4.0l is different than 4.0l listed in my hayes repair manual.
I appreciate any help you can offer!
Thanks,
Jeff
If you do a search, you will find Bosch plugs do not run well with Ford's EDIS.
Checking for a good ground seems a reasonable first step, so I'll try that tomorrow.
Is there a separate regulator (not part of the alternator)? If so, where is it?
Thanks,
Gary
