Where to plug in the trailer brake control?? 2002 Excursion
Hi, I am putting an electric trailer brake control into an 02 X limited. It has the factory 7 pin connecter on the back. I have the little wiring harness that splices onto the controller and is supposed to plug in under the dash. But I can't find the plug. Can anyone please point me in the right direction?
Also does the 7 pin have a terminal that is 12v pos for charging the trailer battery, and if so, is it hot all the time or switched by the ign switch?
Thanks, Joel
Thanks, Joel
Hey I found it! Thanks! It was thru that hole just like you said. But another bundle of wires and a big connector was covering the hole. Once I knew what to look for, I just moved those wires and viola, there it was.
BTW, I am a new excursion owner, just picked it up today. It is a 02 diesel with 44k on it. It will be for my wife and for pulling the camper.
