Drivetrain questions..
Old Jul 7, 2004 | 11:08 AM
michaelbarry's Avatar
michaelbarry
Ok..you'll have to excuse my ignorance..as i am new to the old f-series trucks and such....i have 8 lugs up front,and 8 in the rear..could i possibly have two dana 60's?...i think there was a Snow Fighter edition or something that they made that had two 60's...is there any easy way for me to find out if i have a 44 or a 60 in the front?..thanks.
Old Jul 7, 2004 | 02:10 PM
kermit's Avatar
kermit
should be a tag on it by the cover, post the number here and somebody will decode it for you
Old Jul 7, 2004 | 06:22 PM
michaelbarry
couldn't find a tag on it...hmm..?.wonder what i should do now?..i'm sure the tag is there and i'm missin it..but i looked for a good while..about 20 minutes..lol..but some of that was spent scrapin mud off of it with a screwdriver..
Old Jul 7, 2004 | 06:33 PM
F150daniel's Avatar
F150daniel
D44HD had 8 lugs
Old Jul 7, 2004 | 06:39 PM
michaelbarry
oh ok..is there really much difference in D44HD and the D44?..
Old Jul 7, 2004 | 09:20 PM
SoCalDesertRider's Avatar
SoCalDesertRider
As you're looking at the axle from the diff cover side, look on the lower right hand corner of the center section casting, just outside of the diff cover. On that web should be cast in the model number, either '60' or '44'. You can also compare the size of the diff covers. The rear one you can assume is a model 60. If the front one is a 44, the cover size will be smaller. Also, most model 44 front axles use ball joints, most model 60 front axles '91 and older use kingpins instead of balljoints.
Old Jul 7, 2004 | 11:31 PM
michaelbarry
ok..thanks alot..i'll try to find it tommorow..i'll post results..
