cast vs stamped 2wd radius arms
what are the differences between the cast iron radius arms and the stamped steel ones (other then the obviuos )
I've seen a few 73-75 f250s with cast radius arms. My 79 f150 has stamped steel radius arms.
are the cast arms a F250 specific part or are they a earlier design and thats why i haven't seen them on later 70's trucks?
early cast/late stamped?
or
F250 cast/F150 stamped?
or
I believe the early models are forged steel, as camber alignment is effected by bending the beam, which a casting would not tolerate. In any event, cast or forged employs a king-pin whereas the stamped employs ball-joints. The earlier method will, IMHO, will take more abuse that the later design, although there is nothing inherenty wrong with it (compared to the earlier design). My 78 F-150 has the forged as does my 77 F-250 and there is no difference I can see. If there is a difference between 150/250/350 forged I-beams, I am curious as to the particulars.
96GreenBearF150
01-21-2016 02:02 PM
Backflip164
12-02-2014 02:45 PM
balingwire
09-19-2013 10:46 AM
flyboy2610
01-24-2002 03:10 PM
