Aerostar Ford Aerostar
front end noise
Old Jul 7, 2004 | 07:36 AM
rml121's Avatar
rml121
Question front end noise
I have a 1997 eextende xlt 4x4 van and over the last month or so have noticed a whining or humming noise coming from the front of the van when it is moving. There is no noise when it is stopped. I have changed the transfer case oil in the last month. When you are driving and you turn to the left atleast 20 degrees the noise stops until you start to straighten out. Does any one have any ideas what this could be and some guidance on whether I can fix it at home or if it is better to have it done at a garage.
Old Jul 7, 2004 | 03:14 PM
Muffinman's Avatar
Muffinman
Check CV boots for tears. If none you could have a bad CV Axle.
Old Jul 7, 2004 | 05:46 PM
rml121's Avatar
rml121
The van is also pulling to the right. If the cv joint is going that could explain this. I will have a look. Thanks
