Tire Size
Old Jul 7, 2004 | 07:08 AM
flipster05's Avatar
flipster05
Thumbs up Tire Size
What's The Widest And Tallest Tire I Can Put On My Stock 2001 Ranger Xlt 4x4 Off/road 3.0 W/the 16x7 Stock Wheels On It.
Thanks For Any Info. - Roger
Old Jul 7, 2004 | 08:16 AM
Waves's Avatar
Waves
My best guess would be 31x10.50x16's...bigger than that, especially wider than that you will more than likely have rubbing issues....
Old Jul 8, 2004 | 01:40 AM
98xlt4x4's Avatar
98xlt4x4
Do a quick search. This has been covered a ton of times. With 16x7's, you should be able to put 265x75/16's on with no problem. I see quite a few stock rangers with them, they're slightly taller than a 31x10.50/15. You'll probably notice a small loss of power when increasing tire size, especially with a 3.0.
Old Jul 8, 2004 | 09:36 AM
Diabolic's Avatar
Diabolic
Is it true that you need to do something to your spedometer after you put on bigger size tires/rims?
Old Jul 8, 2004 | 09:53 AM
Waves's Avatar
Waves
You can either have your computer re-programmed for your bigger tire size by the dealer, here in Houston they charge $80 for this, or just live with it. I havent had mine fixed, but I know exactly how far off it is at the difrent speeds. The only advantage to not having it corrected is your odometer will show less milage than you actually have -
