...F-Disk???
Old Jul 6, 2004 | 06:00 PM
wabiker's Avatar
wabiker
...F-Disk???
....Looking for some "how to" info on F-disking the hard drive....basic step by step stuff if possible...or sources for said info....Thanks all...!!
Old Jul 6, 2004 | 06:04 PM
WhëëlMå1's Avatar
WhëëlMå1
Can you fill me in? What exactly is F-disking?
Old Jul 6, 2004 | 06:07 PM
TJC1989's Avatar
TJC1989
Check and see what kind of partition you are using or want, such as FAT, FAT32, or NTFS, or decide which you want and why and then proceed.
Old Jul 6, 2004 | 06:11 PM
Pikachu's Avatar
Pikachu
Well, as you may or may not already know, fdisk will wipe anything off your drive which is there and allow you to change the partitioning of the hard disk drive(s). Basically, you need to boot from a startup floppy, then type fdisk at the command prompt. There will be a menu to choose from, but without knowing why you would want to use fdisk, I can't make recommendations on which options you would need....
Perhaps with more info, I can be of more assistance.
Old Jul 6, 2004 | 06:12 PM
TJC1989's Avatar
TJC1989
Fdisk partitions the hard drive into specific partitions and sizes, and preps it for formatting. Also removes the existing partitions. Not for the amateur. When the hard disk has its partition removed all data is lost. Only do it if you plan on reloading your Operating System from scratch.
Old Jul 6, 2004 | 06:16 PM
WhëëlMå1's Avatar
WhëëlMå1
Ahh. When I want to reformat and reload, I can use the windows console function of XP, via booting from disc, and it does the rest for me. Guess that's just a term I haven't heard before.
Rich
Old Jul 6, 2004 | 06:27 PM
TJC1989's Avatar
TJC1989
Rich
Absolutely. Fdisk is Old DOS, but still used.
Old Jul 6, 2004 | 06:28 PM
acerockola77's Avatar
acerockola77
If you are trying to earase your hard drive, what would be easier is to just use a boot disk goto the dos prompt and "format c: /s" then reload your operating system, you'd have to format when you F-disk. The only time you'd really need to use F-disk is if you are changing the preportions of your partitions.
Old Jul 6, 2004 | 07:29 PM
Torque1st's Avatar
Torque1st
Posting Legend
There are other utilities that are made for changing partition sizes etc. Try Partition Magic, I have had good luck with it for years.
Old Jul 6, 2004 | 10:10 PM
pfogle's Avatar
pfogle
Actually there are times when F-Disk must be used, say you have a boot sector virus, you turn on the write protection on the boot disk, then fdisk the drive.
Old Jul 6, 2004 | 11:09 PM
Pikachu's Avatar
Pikachu
Yup, that's one situation in which you'd definitely use fdisk. I deliberately didn't get too specific about that utility without knowing the reason he wants to use it. The last time I used it was on my tower before I installed Linux and win to "duel" boot. Now I wish I hadn't bothered with windows. lol.
Old Jul 6, 2004 | 11:11 PM
pfogle's Avatar
pfogle
I know that feeling, if there was a decent windows emulator that was free, I would'nt even run windows.... But I use w2k which is far more stable than 98 or XP.
Old Jul 7, 2004 | 09:06 AM
wabiker's Avatar
wabiker
...Yea I may or may not need to do it. Basically Im trying to figure what it entails. Ive lost some of my system tools (defrag, scan tools) and msconfig and Ive tried to reformat (several times). the system is a upgrade from win98 to win2000 so none of my original gateway operating disks will work, it currently has ntfs....I was thinking of starting over from scratch (someone mention f-disking once) Im about 2-steps from chucking the whole thing into the garbage.
thanks all
Old Jul 7, 2004 | 09:14 AM
jdadamsjr's Avatar
jdadamsjr
like stated - this is not for the light hearted :-)
SOME IDE type drives do not LIKE F-disk....
you may need their own "software" for repartitioning...
like go into Compaq's web site for their hard drive utility if a compaq drive, etc...
Have heard of F-Disk destroying hard drives in the past...
(Not just the data - the hard drive was non-functional after F-disk)
Old Jul 7, 2004 | 11:23 AM
wabiker's Avatar
wabiker
....well it sounds like its out of my league. Not being able to go online (Im at work now) is what set this whole ball rolling....
thanks for the input yall....
