Engine ID
Old Jul 6, 2004 | 04:30 PM
C@ppy1961's Avatar
C@ppy1961
Engine ID
Hi all,
Just wondering if anyone can help me ID the motor fitted in a customised car i own. It is a Ford 5 litre and the engine number stamped above the starter motor is E7TE then either "o" or "c", cant quite make it out followed by an A. Would i be right in saying it was originally a EFI ( now running carbs) roller block 5.0??...could anyone also tell me from the above number what car/truck it was originally from...and what the standard BHP would be as fitted with EFI??..BTW, great forum!
Many Thanks
Andy Slaney
Old Jul 6, 2004 | 10:53 PM
mattri's Avatar
mattri
E7TE should be an 87 truck engine and if it's a 302 then yeah, it would be the roller block.
Old Jul 7, 2004 | 02:57 PM
C@ppy1961's Avatar
C@ppy1961
Thanks for the reply mattri ,
Would you ( or anyone else here) know what the compression ratio would be for this motor?..also what type of rockers would it have...stamped, rail???..Reason i ask is i'm hoping to uprade performance, possibly using the Edelebrock Performer RPM package (inlet,heads,cam,carb & headers)..and i need to know if i need to renew or upgrade any of the valve train...any other advice or general comments from yourself and forum members would be appreciated.
Many thanks
Andy
Old Jul 7, 2004 | 05:24 PM
mattri's Avatar
mattri
Sorry, that's about all I know for sure. You might check fordmuscle.com they do a lot with the small blocks.
Old Jul 8, 2004 | 01:46 PM
Kemicalburns's Avatar
Kemicalburns
that sounds like the head stamp not the block.
Old Jul 8, 2004 | 02:16 PM
C@ppy1961's Avatar
C@ppy1961
Hi KemicalBurns,
I took the number from above the starter motor ( had to remove starter to view), Would this be the correct number?
slaney30
May 2, 2013 01:49 PM
slaney30
13
Sep 21, 2012 08:16 AM
slaney30
Aug 1, 2012 04:32 PM
akstraw
Feb 2, 2009 02:28 PM
Andy B
16
Feb 11, 2008 01:30 PM
