Newbie, Serious front end probems
History...I was tooling around a buddy's farm, birds chirping and all then Bang!! One grass covered ravine/creek just a little deeper than the wheels of my truck. I think I was doing about 25 or so and I plowed right though it. I was able to make the 40 minute drive home thank god!
Damage... bumper, to driver's side quarter panel to driver door all shifted (no bigger) I believe the radius arms are bent along with the pivot brackets (Maybe, not sure). The wheels were shoved back a bit thus pulling all the steering stuff along with it including the shaft from the steering box. Well, the steering box still has it's shaft, the seal is leaking like crazy!
Plan... remove the wheels, all steering linkages, swaybar, radius arms/brackets, and pivot brackets. Then put it all back fixing the small stuff along the way.
Questions...
Does the plan sound accurate?
Anybody ever replace the pivot brackets? Where do you get them?
Do you think the steering box is rebuildable?
Is there anything else I really need to look into on this one.
Thanks for you time, I will have to post some pics once I get the mud sprayed off. Almost forgot... it is a 94 150 4.9L 4WD
The wheels are sitting like /---\ and the passenger side is alignment is way off. Before the trouble, I knew by ball joints were failing because of inside ware. Could I have just finished off the ball joints and reall hosed up my steering?
Here is the links to my pics as promissed.
http://www.smartfishes.com/photos/truck
to check ur ball joints, jack up under the arm and get a long pry bar and jam it under the tire and pry up. if loose then replace. also grab at 6/12 and shake up n down...
dont know what else to tell ya
I am begining to think that all the steering links are hosed. The drive alxe comming out of the gear box seems pulled and leaking.
The only thing I am can't figure out is what is making the camber look like /---\
How is camber adjusted?
When looking at the ball joint I can see it seems to be slanted over some too, I think that might be adding to my camber problem as well. Let me tell you it is way out!
