I towed a 4000lb trailer this weekend from KY to NC and back. Every other time I have towed with it it has never got hot. This time though, It got all the way to the top of the NORMAL bracket and then it took it about 5 or 6 miles to cool back down halfway. It normally operates over the O and barely moves when climbing a hill then immediately drops back down.
Initially, I thought it was my SCMT overfuelling so I reprogrammed it to stock. I am running a Banks DP and a 5" exhaust. Coolant, SCA and Oil levels are fine.
Don't know how many miles are on your rig, but it might be the water pump starting to go?? I'd definitely flush and re-fill and check the thermostat first (WAY cheaper) but that's my first thought. Also while you're at it make sure your SCA levels are good in the coolant.
I Just Turned over 130,000 Miles on the trip. This makes 29k happy miles for me and 101k for a landscaper pulling bobcats. SCA Levels are Fine (NAPA TEST STRIP) as I add Them Myself. I believe that I am Going to flush the entire system and replace the Tstat, Then hope it is not the water pump for $$ sake
HeatStroked, I keep on thinking about getting a REAL Guage for temp and oilpressure too. Any brand reccomendations
I have installed gauges 4-6 and one was a coolant temperature gauge.
I compared the coolant temperature gauge to the factory idiot gauge and at about 160 - 165 degrees the factory gauge will sit in the middle. My PSD runs at about 190 degrees and the factory gauge still sits in the middle.
Buy a gauge that matches your others, if you have them. I have Autometers but there is wide variety of choices and price ranges out their to choose from.
