Cooling problem
Old Jul 6, 2004 | 02:57 AM
chebberd's Avatar
chebberd
Angry Cooling problem
I have a 77 f250 that now has a 400ci in it and it tends to over heat. I've replaced the water pump, thermostat, upper and lower hoses, flushed the cooling system, and the fan shroud is in place. I've been thinking about putting ether a flex fan or a fan clutch in it, but I don't know witch would be the best, or if ether would even help (also thought about adding an electric fan with thermostat).
I've also been wonder if timing could be the issue. The under hood sticker is gone and I haven't been able to find any info on what the timing should be.
There is always a load on the truck from the cab-over camper that stays on it so I need to keep the temp down when I dive it. (It's a real pain having to stop all the time when I'm trying to go camping to let the engine cool down)
Old Jul 6, 2004 | 03:25 AM
Torque1st's Avatar
Torque1st
Posting Legend
Does it overheat going down the highway or in slow city traffic? By overheating do you mean the gage rises or does it boil over?
Old Jul 6, 2004 | 10:08 AM
dfisher1's Avatar
dfisher1
cheb,
Is there actual evidence of overheating?
Does it actually boil over? Does it ping? Is it hard to get to restart when at temperature? That is, does the starter lug or turn over slowly?
How long does it take to overheat?
Get a few of these questions answered, and I'll try and fill in the blanks.
KingFisher
Old Jul 6, 2004 | 11:52 AM
chebberd's Avatar
chebberd
Torq,
It tends to overheat above 40-45 MPH when going up hill. Once over the hill It will cool back down. When it over heats and I'm not watching the after-market gage it will boil over.
dfish,
It is hard to restart and turns over slowly, and it can happen withing 10-15 miles if I go up a long hill under load.
Thanks in advance for the help.
Old Jul 6, 2004 | 01:03 PM
beartracks's Avatar
beartracks
Was the original motor smaller? A four core radiator is normally desired for a working 400. A good clutch fan and shroud is also a good idea.
Old Jul 6, 2004 | 02:27 PM
olfordsnstone's Avatar
olfordsnstone
If the radiator is REALLY clogged, the radiator flush is ineffective. You may need to take the radiator to a radiator shop and have it rodded out or recored.
Old Jul 6, 2004 | 05:13 PM
freak98's Avatar
freak98
How's the timing?
