99 F150, 4X4, SC, auto: How do I decifer the tag ,and I need a cover gasket, my parts store says it lists only one for 12 hole cover. The gasket is right design but a bit too large.Is there something more to go by?? I need to change an axle bearing. Thanks
The second line of the axle tag will give you the ratio in a three or four digit alpha numeric code (3 55 or 3L55 the 3 is usually under the bolt) then the ring gear size. If the parts store doesn't go by ring gear size I'd be nervous.
No I did not, checked 2 parts stores, they list 2 gaskets, 12 or 10 hole, mine is a 12 but different size, so I'll have to use silicone I guess. What silicone would you recommend ?
So mine says L55 88 6F07. (Wrote this down before I saw thread and didn't realize that there may be a # under bolt.) So I am assuming that I have Limeted Slip 3.55 with 8.8 gear? What do the rest of the # mean?
Thanks Racerguy, I'll do the silicone thing. Axle bearing is just starting to get some play so I figured I'd tackle it before it got worse, plus it's boat towing season. So thanks again.
Anything tips I need to know before tackling this? It seems pretty cut and dry from the manual, when you pull the pin partially out of the differential, does the side gear fall out of place??
97Centurion,FelPro makes a 8.8 differential gasket.It is part # ;
FelPro RDS-55431
I get mine at Advance auto parts.They will most likely ask you the year application,then say it dont call for a gasket.Just give them that part # ; it fits all 8.8 differentials.
