Changing ATF
Old Jul 5, 2004 | 07:39 AM
model-a's Avatar
model-a
Changing ATF
I went to drain my torque converter and there is no access port on the bell housing. Does this mean there isn't a drain plug in the TC? I suppose I could drill and tap a hole, but where?
Old Jul 5, 2004 | 08:31 AM
Rockledge's Avatar
Rockledge
Welcome to FTE!
What year and model truck do you have?
If your TC does not have a plug, then the recommended method of ATF exchange is to flush it. Many local shops can do the whole ATF exhange for you these days, costs about $60 bucks or so around my area.
To flush it yourself, you can pull off the tranny cooler return line, using a procedure similar to the one described in this article:
https://www.ford-trucks.com/articles...hangingatf.php
