Well, of course anything can be put into anything. But I have a 96 cobra with the dohc 4.6 liter motor, It is a tight fit in the mustang. The heads/valve covers are very wide and I don't see any easy way to fit it in a ranger. Look up the engine width and I think you will see what I mean.
Dave
Alot of those 5.0 rangers actually have a chevy 305 in them, it's narrower and fits easily in the engine bay. I have seen 351w swaps, but I can't imagine trying to change the spark plugs....
well the parts person i spoke wiht at local ford place about motor wasn't very helpful, saying its a waiste ect, and wouldnt help me out on legality issues >would it pass inspection< so im still up in the air on exact motor, but i want that basic 5.0 or 4.6 block, and decided on 8.8 rear because of price heh... yea a 5.4 triton would be nice power for a truck but thats adding more weight, i think that motor is a full 200 more than the one in it now ... were as the 4.6 is 100 more or 80 i cant remember
The 5.4 would be alot tougher cause it and the 4.6 are similar except that the 5.4 is taller. The 4.6 and 5.4 have the same bore the 5.4 getting the extra ci from a longer stroke, making it a taller block. Now assuming that the cylinders in the 4.6 and and the 5.4 have a similar angle, that makes it somewhat wider too. Theres also the electronics nightmare that comes w/ the triton sohc engines. Frankly, I would say you would be alot better off sticking w/ the 5.0 simply cause you'll get the most ci for you outside dimensions, plus they have hop up parts galore.
i'll be un-bolting as much of the front as i can < fenders, wheel wells, raidator mount grill, everything i can > to make room, so it will be the fenders/wheel wells that will have a hard time
altho with the body lift < which i have never done or seen done, oui > ill get more clearance ect
A- An extra set of hands
B- An impact wrench
C- Time
D- 2 Jacks, preferably floor jacks so you can move the stuff around to align properly.
If you have those things, it's relativly easy. Also make sure you have the proper torx bit to remove the bed. Put a 3" Trail master body lift on my 91 ranger in about 6 hours. You may altough have to get a little clever w/ bracket modifications to bring the bumpers up. I ended up having to flip my rear brackets upsidedown and then weld the bumper to them to make it look right.
James Duff Enterprises motor mounts $43.75
James Duff Enterprises dual-shock mounts 175
James Duff Enterprises motor mounting plates 45
James Duff Enterprises dual sump oil pan kit 145
James Duff Enterprises remote oil filter 59.95
James Duff Enterprises 2" body lift 113.25
James Duff Enterprises body mounts 59
James Duff Enterprises long link traction bars $287
summit racing . com electric fan 220
Summit Racing.com aluminum radiator 300
Currie Enterprises CE-6012D Explorer disc brake kit with cross drilled rotors x2 if useable on front $439.95
Currie Enterprises 88-1005 Mustang 8.8" rearend housing with "stock cover and companion flange 8.8" housing with CE-0012 performance axle package $989.95
Currie Enterprises 88-373 3.73 ratio gearset $199.95
Currie Enterprises 88-0111 Set-up labor $119.95
Currie Enterprises 88-0118 install axles and brakes $49.95
1799.75
Dakota Digital VFD3-1010 Six Gauge Designer Instrument System $595
Ford Motor Co. M-6001-C469 Complete ''Signature Series'' engine and transmission package for 1999 Mustang Cobra $5,795.00
heres my list so far, anyone see anything i need to add ? <IM site web performance ford off it got i but package, transmission motor in is all what see to calling>
I understand and respect what you are trying to do, but all that cash would go a very long ways on the down payment for an '04 Ranger 4X4 4.0L. That is my plan for getting more power from my Ranger. Trade it in for a new one. Of course, if I had the extra money I'd buy myself the new Ranger and completely Baja my current Ranger. Good luck!
