Extremely Hot Tail Pipe / Emissions?
Old Jul 4, 2004 | 05:59 AM
mpmccarthy's Avatar
mpmccarthy
I have a 1988 460 EFI. It is on a Motorhome built on an E350 frame.
The last 3 feet of tail pipe has been missing for about a month and yesterday I got around to replacing it.
The first thing I noticed was that the emissions from the tail pipe were extremely hot. You can't stand to have your hand in front of it for more than a second. Of course the tail pipe would cook a steak in about 3 seconds.
I don't think I have ever felt an exhuast that hot. Any ideas as to why?
Old Jul 5, 2004 | 07:02 PM
fastback69's Avatar
fastback69
The operating temp of a catalytic converter is around 800 degrees. My 4.9l has a full exhaust system and it gets hot, too.
Old Jul 5, 2004 | 11:25 PM
tkondro's Avatar
tkondro
Its an explosion which equals fire coming from the combustion chamber. Fire is hot. The longer the pipe the more time it has to cool due to the heat lost from the pipe to the air. The shorter it is, the less time for heat transfer from the pipe.
Old Jul 6, 2004 | 12:05 AM
351M's Avatar
351M
Yea having a converter in the system will heat the pipe up alot more than a system without. A guy I know has stainless tips on his truck and on the trip home with the new system the tips turned gold, I would assume that was due to the heat?
Old Jul 6, 2004 | 08:39 PM
5_labsownus's Avatar
5_labsownus
Check to see if the engine is running too hot. It may not be over heating but the temp is too high. see if it running too lean and the timing is correct.
The fan (clutch) may be weak.
3twinridges
19
Jul 24, 2016 07:04 AM
PaRambler
May 31, 2016 01:09 PM
zapola6
Aug 14, 2015 01:14 AM
glockholiday
16
Aug 11, 2014 10:30 AM
Frenchy
Paint & Bodywork
Jun 5, 2012 02:01 AM
