Late model Conversion
I'm kinda new here too. But I have read here that you can swap the whole frame for our 61-66 trucks with frames up to 79. Same wheel base. You get a more modern truck under the old sheetmetal. Power steering and brakes improved suspension
My 66 has a 75 302 with 600cfm 4bbl and a little more cam than stock. It is also a 67 C-$ automatic. Moves the truck well
Soon others will chime in with more info.
Good luck, Brian
66 F-100 Custom Cab LB, 302, C-4
Check out his link for the details on the disc brake swap.
http://www.mongrelmotorsports.homest...f100discs.html
There is alot to be found here on these swaps, be sure to search for them!
swapped p/s, p/b, out of 75-76 donor truck for my 65 100, w/ 302. Have the T18, 4 speed so kept the original column and cut the steering shaft approx. 2", kept the steering housing intact. Have not installed the column yet, but appears will align perfectly. If you run search on Bendix p/s i posted the question and received much good info.
If you run a search on the topic in this forum you should find several post on the subject. There will likely be other members more knowledgeable who will be able to provide additional information.
good luck,
dave
