I am wondering if a 352 will fit into my 1964 f 100 that has a straight 6 in it .If so how much work or modification am i looking at . If anyone could answer my question i would greatly appreicate it thank you
Jesse,
1st off, You gotta use a different font, Impact Font is definitely too intense!
2nd, welcome to FTE 61-66 forum page. ALways glad to see new members here in the forum. Now to get on to your opening question. . . . .
A 352, other wise known as a FE engine (from FE Group) was not available until 1965 in F Series Fords, so as far as being a drop in-bolt up swap it's a NO. . .
But there are engine mount kits, crossmember conversions & so forth along with other options available now which make this retrofit easily possible.
If you have the skills and resources you can also fabricate the needed components for the conversion, as we had to do before they became commercially available in after market parts and custom accessories shops.
The main problem is engines 64 & earlier used front mounts with side/ trans mounts on bell housing & from 65 or later, engines were side center mounted and used a rear engine/ trans X member to support trans & rear engine weight.
As far as size in your engine bay there's plenty of room for an FE, even a 385 series such as a 429 or 460, or smaller diesel engine have room to spare in the engine bay.
Hope this helps you.
FBp
is there anything i can do to the straight 6 thats in my 64 truck to increase hp im not really worried about top end peformance but i sure would like to get some healthy low end torque . a little tire smoke if you know what i mean
