a few questions
Old Sep 19, 2002 | 07:48 PM
dave05065's Avatar
dave05065
a few questions
well here we go
i have an explorer sport mfg on 7/94
?1 what do i have for a transmission it's an automatic with o/d
?2 do i have the traction lock in my rear differential ie clutch plates
and i also have a problem and i am not sure what the answer is
i am traveling down the road and when i come to a complete stop i could be stopped for a few seconds then i release the brake to take off again i hear a clunk and the rig feels like its in neutral the quickly goes to drive now would that be my differentil slipping if i have the traction lock or is it my tranny tranny slipping or my vacuum diaphram short on vacuum prressure
Old Sep 20, 2002 | 09:52 AM
mrshorty's Avatar
mrshorty
a few questions
1. '94 model year explorers came with the A4LD transmission. '95 came with a 4R44E?? The A4LD has earned a bad reputation as far as longevity goes.
2. You'd have to check axle codes (either on the door jamb or the tag on the diff) to tell if you have the traction lok differential. I don't know though the information is out there how to interpret the door pillar codes, the code on the diff tag will contain something like 3 73 or 3L73 on the second line. The L means traction lock, without the L means open diff. the numbers represent the gear ratio(3.73).
As for your problem, I'd look at the transmission. The differential, open or limited slip, shouldn't contribute to a hesitation like you're describing.
Old Sep 20, 2002 | 01:41 PM
davidri's Avatar
davidri
a few questions
Brianut
1966 - 1977 Early Broncos
Nov 8, 2010 12:39 PM
Tyson0317
Jun 1, 2008 02:03 PM
randyh1
Feb 3, 2004 10:25 PM
AG4.0
1983 - 2012 Ranger & B-Series
Dec 11, 2003 04:56 AM
brs127s
Mar 19, 2002 04:43 PM
