Offroad & 4x4
Found my size.
Old Jul 4, 2004 | 03:20 PM
95-F-350-4x4's Avatar
95-F-350-4x4
LOL yep!
Old Jul 4, 2004 | 05:31 PM
SoCalDesertRider's Avatar
SoCalDesertRider
4.10's will be fine with 33's and overdrive. 4.56's with 33's is what I have, and with overdrive it would be good. 4.88 is getting a little low for 33's. Unless you have dreams of running 35's or larger in the future, I would stick with 4.56 or higher (numerically lower) for the 33's. If you want really low gears for rock crawling, look into a transfer case low gear kit or swap to an Atlas case or add in an underdrive unit (like a US Gear) or a doubler box.
Old Jul 5, 2004 | 12:12 AM
81f150on40s's Avatar
81f150on40s
my 2 cents......i would steer clear of the birds,on a yota or mini truck they arent too bad(them trucks cant take a real tire). i had 38 inch birds on my truck,and hated it.they didnt look good,they rode worse than an unbalanced ground hawg,they wandered,and they wore out extrmely fast.they seemed to do ok in mud as long as there was already a rut cut,and they seemed to like thicker mud.they also cut extremely easy,i gladly ditched mine for some 1/4 tread tsl's. with a bird you need to keep the air pressure in check,you DONT want them side lugs touching pavement.if it was me,and it was a daily driver/commuter...i'd buy bfg mud terrains,they ride great,last forever,and arent but so bad off road.
PA74F250
48
Apr 25, 2013 02:07 AM
MNbandit
Offroad & 4x4
Apr 13, 2010 09:46 PM
chrono4
Offroad & 4x4
Feb 5, 2008 12:12 AM
Bogn
Jan 8, 2005 12:26 PM
dassmoof
Offroad & 4x4
25
Jan 11, 2003 05:48 PM
