302: two different bellhousings?
Old Jul 2, 2004 | 08:26 PM
brown 4x4's Avatar
brown 4x4
I was talking to a guy today that had recently swapped a 302 in to one of his older cars. He was saying he had a little trouble because there was there were 302's with two different bellhousings. Now that I've thought about that all day, I vaguely remember hearing that somewhere. What was the deal? Were the very early ones different, then they changed to the standard "small block Ford" pattern?
Old Jul 2, 2004 | 10:25 PM
f100guy's Avatar
f100guy
i believe they are all the same
Old Jul 2, 2004 | 11:46 PM
Cheggie's Avatar
Cheggie
289
289's had two different bellhousings. The pre '65 had a 5 bolt belhousing, and the '65 and up had the familiar 6 bolt bellhousing that continued when the 289 was enlarged to 302.
Old Jul 3, 2004 | 12:49 AM
fordborn's Avatar
fordborn
actually changed in mid 65 some early 65's will have the smaller houseing.
Old Jul 3, 2004 | 11:28 PM
lghtningstruk's Avatar
lghtningstruk
The 6 bolt small block bellhousings are the same as far as the bolt pattern, but the actual internal size of the bellhousing may be different depending on if it came frome a 28 OZ balance or a 50 OZ balance flywheel (in the case of a C-4 anyway - not sure about a C-6 or FMX). Most 50 oz flywheels have more teeth than a 28 OZ. More teeth makes the flywheel OD larger. There are aftermarket companies that make the smaller flywheels in the 50 OZ balance though.
