disc brake conversion
EDIT:
never mind, I found it thanks anyway, anybody have any info on a power steering conversion for the 69 f100?
thanks
Trail Rider
Search the '61 - '66 forum for great details on the PS and PB swaps. Be sure you reference the '65 and '66 trucks only because the '64 and earlier trucks are not the same.
I am still a believer in swapping the entire front end. It can be done in a day with simple hand tools. The biggest benefit is when buying parts. Instead of having to tell the parts guy at the counter (who has no idea what they're doing in the first place), I need kingpins for a 70 F100 with 77 spindles, you can just tell them I need kingpins, pads, rotors (or whatever you need) for a 75 F100 (or whatever year your frontend is).
Trail Rider
Scott
Luck with pdb conversion was not what I had hoped for. I worked all day the first Fri and Sat and the Big Red Truck was still up on blocks.
Here's what I managed to get done in two days:
1) took off old I-beams and steering linkage, installed new bushings on '78 beams
2) test fit '78 beams (test failed, too wide),
3) moved new bushings off new beams onto old beams and reinstalled on truck,
4) moved new spindles and rotors off new beams onto old beams, kingpins were a bitch
5) spit on truck (both days)
Left to do on the second weekend was:
1) install calipers (needed caliper support keys)
2) reinstall steering linkage (used '78 linkage that came with disk spindles)
3) swap out pedal assembly (put '75 pedal on '68 bracket with new bushings)
4) swap out m/c and add booster
5) install new plumbing (inverted flares aren't as hard to make as you may have heard)
6) bleed the system (had to replace one rear wheel cylinder after I rounded off the shoulders on the bleeder valve and then broke off an easy-out in the hole)
7) spit on truck one final time
In my opinion, from the standpoint of level of effort required, someone working alone in the driveway is much better off to just leave the I-beams in place and swap only the spindles. That's assuming two things. One, that you can get your kingpins out (not a small task if they're original equipment) and, two, that there's no need to replace the I-beam and radius arm bushings. It took me two jacks, a come-along, a couple of big c-clamps, a pipe wrench, a crow bar and some miscellaneous shims and wedges to spring my beams back into place. Plus, if the spindles and rotors are mounted, I doubt one guy can do it at all simply because of the off balance weight distribution.
I swapped out a 3-speed tranny for a c-6 and I swapped out my old armstrong steering for power. I'd do either again in a heartbeat. There was mental effort as well as physical labor involved in them and I truly enjoyed meeting the challenges those projects provided. I will never try to frig with another I-beam. I grew weary of the project very quickly, unfortunately long before I finished.
Dan Blackwell
Dan
1. If you are changing the engine from one type to another, say from six to a V-8. This doesn't always hold true, so double check.
2. If upgrading to power steering from factory manual steering the driver's side perch may interfere with the power steering gearbox. Early perches, especially for the FE, were straight across, and the Ford power steering box made by Saginaw cannot be installed without cutting a notch in the perch.
The later FE perches (driver's side only in this case) are mounted a little further foward on the frame, and swept back at an angle to meet the engine at the same block mount point.
So, it is probably a little easier and definitely a whole lot nicer looking to change out the perch for the correct one.
