HELP!
Old Sep 21, 2002 | 06:21 PM
Droptopfiveo's Avatar
Droptopfiveo
HELP!
I have a 94 ford explorer and I'm tring to remove the ingnition Cylinder in the steering colum. There is suppose to be a push rod or pin you press in while the key is in the run possiton and then it should slide right out. The problem is I can't find the pin to push in so that the cylinder can be removed. This is a 94 ford exploer I've looked all around the cylinder and I still can't find this damn thing. Any help would be appreciated.
Old Sep 21, 2002 | 07:20 PM
alanscott's Avatar
alanscott
HELP!
How about using a hot wrench? (torch) Or you can try the Explorer forum for better responses
https://www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=explorer&conf=DCConfID9
Old Sep 21, 2002 | 09:29 PM
CobraXP's Avatar
CobraXP
HELP!
Crazy66Dog
May 21, 2013 04:32 PM
cesspool
May 11, 2010 10:11 AM
skippr76
Feb 20, 2008 03:33 AM
93Mule
1978 - 1996 Big Bronco
Jul 23, 2006 11:24 AM
Droptopfiveo
Sep 25, 2002 06:29 AM
