1995 Explorer door beeping!!
Old Jul 1, 2004 | 10:28 PM
TheViper90210's Avatar
TheViper90210
well i have a 1995 explorer, and i have been trying 2 find out about how to disable the beeping in the door when the doors open and the key in the ignition, well i found the box up under the dash and found the Gray cable in it that connect to it, but it has so many wires in the conector, so when i unpluged it i saw that the overhead lights didnt work so i figured that was tied into that conector but what i want to know is what is the wire in the conector that make the beeping part work what color would the wire be in a 1995 explorer and could i just cut it to disable the beeping?? PLEASE HELP!!!
Old Jul 2, 2004 | 06:45 AM
HomerWinzlow's Avatar
HomerWinzlow
If you disable the door ajar circuit you will also lose dome lamp operation. Key in ignition chiming can be stopped by cutting the wire that comes from the clockspring to the ignition lock cylinder.
Old Jul 2, 2004 | 07:45 AM
ranger88a's Avatar
ranger88a
I just pull out the key cylinder and remove the connection, tape it up and push it behind the plastic shroud. That way should anyone ever want to reinstall it they can.
Old Jul 2, 2004 | 09:42 AM
TheViper90210
ok where is the key cylinder to remove, what does it look like, please help me out here give me some details!, PLEASE
Old Jul 2, 2004 | 01:05 PM
ranger88a's Avatar
ranger88a
Turn your key cyl to run position, look underneath the key area you should see a small hole in the plastic cover approx 1/4 in. diameter. put a small pick into the hole and you should be able to feel it push up against a spring and ball. Push up and pull out the key cyl. Remove a small black plastic piece with a brass contact on it. Tape up the brass piece, replace the cyl. and your done.
Old Jul 2, 2004 | 05:57 PM
TheViper90210
ok man thanks alot ill try that tomorrow, can you tell me if i will lose anything else in the car, like will the over head lights stop working if i do this, or will everything work fine?? THANKS
JessieDM
19
Dec 30, 2024 04:44 PM
87&97Aerostrar
Aerostar
21
Feb 17, 2017 09:06 AM
Oldanvilyoungsmith
Sep 27, 2016 10:30 AM
shadyEats
1983 - 2012 Ranger & B-Series
13
Jun 15, 2015 02:00 PM
boaterdude83
Jan 13, 2013 02:43 PM
