67 Horn wiring?
Old Jul 1, 2004 | 05:06 PM
gtex's Avatar
gtex
67 Horn wiring?
Which wire going into the column is for the horn? Does it ground to complete the circuit or does it go to hot? My initial testing at the relay says it grounds at the steering column.
I'm thinking if I find the right wire, I can just run it to a SPST momentary switch on the dash and ground it.
Whaddaya think?
Old Jul 1, 2004 | 05:21 PM
svt522's Avatar
svt522
The horn switch grounds the relay.
Old Jul 2, 2004 | 02:21 PM
gtex's Avatar
gtex
any idea which wire it is going into the column? My wheel is no longer flush against the column since I did the body swap (changed to Bendiz power steering box from the manual box). So the horn ring no longer actuates the horn. I need to rig up a pushbutton horn on the dash to get legal.
I tested the relay and it and the horns work. So, I just need to find the wire to plug into a SPST momentary switch on the dash that goes to ground.
Old Jul 2, 2004 | 09:40 PM
Mil1ion's Avatar
Mil1ion
I think it was yellow back then.
n4gnr
35
Mar 31, 2021 06:39 AM
Duckmang
Jul 28, 2013 11:40 PM
flamesoldier
Apr 17, 2013 12:31 PM
Craig Terry
Oct 7, 2012 08:42 PM
