'93 Explorer 4x4 problem
Old Jul 24, 2002 | 11:48 AM
Amaziah_ds's Avatar
Amaziah_ds
Recently my '93 Explorer stopped shifting into 4x4 range when I pushed the switch. I think I hear the solinoid activate when I depress the switch. Where should I start troubleshooting? What are the least expensive problems I could have? Thanks
Old Aug 21, 2002 | 12:24 PM
helyeahmel's Avatar
helyeahmel
Post '93 Explorer 4x4 problem
My 92 explorer is having the same problem, nothing happens when I push the button. People have suggested checking everything from fuses to the electric shift module to wiring. Most suggestions are far to complicated and expensive for me, Good luck!
Mel
Old Aug 22, 2002 | 01:13 AM
92Roger's Avatar
92Roger
My 92 had the same problem. I found the fix on this web site but have forgotten the location. It gave detailed instruction for removing the shift drive motor. I did that without even raising the vehilce but it is easier if you have a little more room.
The 4X4 has shifted fine even since.
The problem lies in the contacts getting dirty or actually getting out of alignment. The shift motor has as part of its housing the contacts in a cap. The cap is held on by three screws pressing down on the cap. This way of attachment can allow the cap to rotate. Slight rotation can cause the problem. As I recall the screws need to have the heads drilled off as they were designed for non-repair by us do-it-yourselfers. Once the heads are drilled off the cap can be removed and the screws can then be removed with pliers and can be replaced with normal head screws. The thread is a common one.
I suggest marking the current cap location because there is nothing to align it to if you don't have a starting point. I did the entire disambly but suspect I could have fixed my problem by just removing the screws and realigning the cap. When I reassembled things it wouldn't shift but all I had to do was to rotate the cap slightly then retighten the screws and all worked just fine. Search this site for the posting. If you can't find it let met know and I will see if I can find a copy of it.
Old Aug 26, 2002 | 05:40 PM
phatpharm85's Avatar
phatpharm85
My grandfather had the same problem with his first gen i forget the exact year but i belive the problem was actually the auto locking hubs. I think it was from nonuse and they dry up or something. Or maybe im just completly wrong. Anybody have any idea no how wrong or right i am!?!?!?
Old Aug 28, 2002 | 09:00 AM
sim's Avatar
sim
I had the exact same problem.
Buy
Sharpie fine tip marker
1" of 1/4" rubber fuel line
3 8-32 1/2 round-head (phillips is better) screws.
Some Gasket compound or similar adhesive
You have to replace a $.02 cent plastic washer located on the Shift Gear limit switch. The plastic gets brittle and shatters, leaving the limit switch out of alignment, and out of commission.
Find the 4x4 Trans shifter motor. This is a small electric motor attached to the trans distribution box. The electric motor shaft is a worm gear that turns a gear in-line (off a tangent) with the motor shaft.
It was easy to remove this whole motor assembly/gear housing. DO NOT CUT ANY WIRES. There is some kind of brown sensor wire in a fitting in the transfer case. It simply pulls out (with a 'pop'.) I think it has a magnet on the end of it.
This gear is covered by a flat metal plate held by three 'security' screws. MARK THE POSITION OF THIS PLATE TO THE HOUSING!!! Clean off the road dirt, and mark a fine line next to a screw housing. (If you're really good, and have lots of light, there are fine degree markings already on the cover!)
I had to cut a notch in them with a hacksaw for a flat screwdriver. (this is the hardest part)
Once the screws are out, you can pull off this cover. You should find little pasty looking plastic chunks that have become brittle and have come off the **** on the flat side of the gear.
Cut a 1/4" - 3/16" washer of fuel line to fit over this ****. Cement in place with gasket adhesive.
Align and Replace cover, using three new screws. Paint exposed surfaces for good measure..
Ford will tell you to replace the whole motor. I found mine in perfect condition. I suspect others find the motor contacts dirty or burned, and perhaps it runs it self to death when the limit switch fails to turn it off.
The whole thing should only take an hour or so. And works like a charm.
Old Sep 29, 2002 | 06:37 PM
ESM's Avatar
ESM
I have a 91 explorer and during the winter I have to puch that button for about 5 minutes before the 4x4 is engagded.
Good luck with fixing your problem.....sorry I couldn't be of any help!
Eric
Old Sep 29, 2002 | 06:41 PM
ESM's Avatar
ESM
Let me try something here.
Do you have the truck in nuetral or park befroe you try to get it in 4 wheel?????
I thought having a push button 4x4 system meant I could push that button on the fly or just sitting in park. But thats not true with my 91 explorer. I have to stop, put it in nuetral, hit the button, then I can go have fun!
Good luck!
Old Sep 29, 2002 | 08:53 PM
mgazak's Avatar
mgazak
[updated:LAST EDITED ON 29-Sep-02 AT 09:56 PM (EST)]>Let me try something here.
>Good luck!
That's only for the 4X4 Low. For 4X4 High, it can be engaged on the fly.
One winter when I went to use the 4X4 on my 92 for the first time, I pressed the button and nothing happened. I heard like a clicking noise. Finally after a couple minutes, it engaged and worked fine the rest of the winter. I think if it isn't used for awhile, things get gunked up, so to speak. Hope this helps.
Old Oct 3, 2002 | 01:42 PM
LittleX's Avatar
LittleX
9 times out of 10 its the transfer case. Click on this link and scroll down to the transfer case section. Its a long and very detailed about how to pull it off your truck and do 1 of 4 possible fixes to it.
http://www.glue.umd.edu/~singletn/exp.html
Old Oct 3, 2002 | 05:25 PM
marragtop's Avatar
marragtop
bf5113x
Dec 20, 2015 09:09 AM
Old93junk
1983 - 2012 Ranger & B-Series
Jan 2, 2015 07:04 PM
93F250
13
Sep 11, 2014 07:51 PM
gdennis51
May 22, 2009 02:11 PM
