4.9 acting funny
Old Jun 30, 2004 | 12:25 PM
Scott Fraser's Avatar
Scott Fraser
4.9 acting funny
I've got a 94 E-150 clubwagon. If you rev it up in park the engine revs up very responsivly, then when you let off the gas the engine drops below idle almost dying, and then back up to normal idle. When it almost dies the volt meter drops and comes back up. Also, when you put it into reverse to back in the driveway the engine almost dies again then catches up. When it catches up you can see a puff of black smoke. What is the deal with it. Can it be the catalytic converter?
P.S. this has only been happening since we had NAPA put a long block in.
Old Jun 30, 2004 | 11:49 PM
c96drumm's Avatar
c96drumm
Any codes? I would suspect the IAC (idle air control) first. Might need cleaned or replaced.
Old Jul 1, 2004 | 06:48 AM
Scott Fraser
Is the IAC something that needs regular maintance?
Old Jul 1, 2004 | 07:20 AM
c96drumm's Avatar
c96drumm
Not really, but I see quite a few idle problems get fixed by cleaning or replacing on this site. Never had trouble with one myself. (yet)
Old Jul 2, 2004 | 09:10 PM
Mustang 5.0's Avatar
Mustang 5.0
IMO, IAC is the problem.
Old Jul 2, 2004 | 11:27 PM
Yakk's Avatar
Yakk
Another common problem is the Throttle Body gasket gets sucked into the manifold inlet and causes a vacuum leak.
I'm not sure when,if ever, Ford upgraded to a more durable gasket though.
The replacement is thicker than OEM and runs like $2
IAC's run about $60
-J-R-
Old Jul 3, 2004 | 10:17 AM
Scott Fraser
Thanks! I'll have to take a look at it.
Old Jul 3, 2004 | 10:50 PM
pfogle's Avatar
pfogle
It may also be a worn timing chain.... Might look into it...
