97 F-350 Running Light Problems
Old Jun 30, 2004 | 08:32 AM
BieselDiesel's Avatar
BieselDiesel
HELP!!!
The light switch on my '97 F350 is not working right. I have replaced the switch and checked all the terminals inside the wirering cluster.
When I pull the **** half way out...NO parking or running lights come on. Pull it all the way, I do get headlights.
Now, if I push it in very slightly (wiggling it) I can get all the lights on. But I should be getting my park/running lights with the switch out half way, and all lights when out all the way, but it's not working that way.
So where is the connection problem??? Please help.
Thanks,
Old Jun 30, 2004 | 10:18 PM
Dealford's Avatar
Dealford
Just wondering what the original problem was before you changed the switch, just running lights?
Are you absolutely sure that all the pins in the plug are not corroded & make proper, tight connections?
I got caught by this once before and it was the park lights too. I used a spade connector on the backside of the afflicted pin to shim it up so it would hold tight.
Hope this helps.
AL.
Old Jul 1, 2004 | 12:32 PM
Franklin2's Avatar
Franklin2
A long time ago on here someone had this exact same problem. He could pull the switch out somewhere in the middle and get all the lights to work.
What he found was the tan/white wire feeding the lightswitch was melted somewhere between the switch and the fuse box. This wire is what feeds the running lights. You might want to check your fuses too. The headlights are fed from a different power wire(usually orange/black).
If your tan/white wire is dead, then pulling the switch out to some weird position will make the voltage jump inside the switch, feeding the running lights from a different circuit than normal. That is why they work sometimes if you mess with the switch.
Old Jul 2, 2004 | 09:16 AM
BieselDiesel
OK....Let's just say I need help..........checking fuses.
Thanks for all ya'lls help. Don't laugh too hard!!!!!!!
Old Jul 4, 2004 | 04:22 PM
Dealford's Avatar
Dealford
Too Late!!!!! ! ! ! ! !
92 Black Nite
Electrical Systems/Wiring
241
Jan 27, 2023 06:16 PM
Belt Driven
22
Jun 11, 2016 05:15 PM
fp_5
1997 - 2003 F150
May 8, 2009 05:13 PM
wjeffofl
Jul 13, 2006 09:23 PM
Ozzy57
Jan 23, 2006 08:38 AM
