1978 - 1996 Big Bronco
Another Problem with window
Old Jun 29, 2004 | 08:35 PM
Blue Tear's Avatar
Blue Tear
Unhappy Another Problem with window
Front left power window will not work the moter is fine as i took it out and it runs both ways just fine but when i put it back in it will pulse up and down but not go any where. kind of like the gears are missing a some teeth but they arnt. Just started yesterday for no reason.
any info would be helpful thanks Bob
Old Jun 29, 2004 | 08:48 PM
ecsmith0624's Avatar
ecsmith0624
Sounds like the bushings are ruined. Not at all uncommon. If you take the cover off the part with the gears on it you will see what I mean. There are three round bushings, maybe 3/8" or so. They're made of plastic so they are usually the first to go. Clean out all the grease from the gears, find a rebuild kit or get new bushings of ebay, put them in, reassemble everything and it should work fine. Really easy to do. Advanced Auto has a rebuild kit with new gears and bushings for around $25, and I've bought just the bushings from a guy on ebay for less than $5. Either way, good luck!
