engine braking
Old Oct 10, 2002 | 11:57 PM
snorider49's Avatar
snorider49
engine braking
:-( I have a 97 xlt explorer and have seemed to have lost my engine braking in low gear. Auto transmission. 4.0 liter. In second gear I have engine braking but in low gear there is no engine braking whatsoever. Going downhill it is as if I am in drive no matter if I start from a standstill or drop down below 20 mph using my brakes. If I shift up to second gear I get the appropriate engine braking for that gear and shift down again it is as if I am in drive. Now if I step on the gas in low gear I have all the proper torque for that gear...no matter the situation...I hope this makes sense and someone can tell me what I need to look for and hopefully something simple in the throttle body somewhere. Thank You........
Old Oct 11, 2002 | 12:39 AM
Racerguy's Avatar
Racerguy
engine braking
The valve body gasket in the transmission is blown out. It's a very common problem. You have to remove the trans pan and then the valve body to replace it.
Old Oct 11, 2002 | 06:08 AM
ExplrSport01Chic's Avatar
ExplrSport01Chic
engine braking
jasoncw
Nov 13, 2013 02:05 PM
DBubba
Mar 5, 2013 01:22 PM
Thumper19
Aug 7, 2012 03:53 PM
ckrichard
Apr 27, 2006 02:57 PM
occupant
Aerostar
27
Jul 31, 2005 09:50 PM
