96 Mazda B4000 4X4 Electrical Problem?
Old Jun 29, 2004 | 07:23 AM
gman39's Avatar
gman39
After I drive my truck for a few miles and get it warmed up, stop and turn it off it has trouble starting back up some times. Also, my radio stations will be cleared as if the battery has been disconnected. The battery has one of the green lights to show that it is still charged and it is green. It seems much worse on hot days. Once the truck cools down it will start right back up no problems but the radio stations will be cleared. It starts easily every morning, when I go to lunch and when I leave to go home each day. Once I drive the 30 miles home it has this problem or if I stop on the way home it may not start. If I get a jump from someone it has no problems starting. I am stumped. The check engine light is on and the codes were 401 (egr code) and 1443 (evap system error), will these codes cause this problem?
Old Jun 29, 2004 | 07:43 AM
cscottyr's Avatar
cscottyr
Hey there,
Have you cleaned your battery termininals and grounds? - Also go to autozone and get your charging system checked out. You probably have a fuse in between the battery and your power distribution system also - check that for cleanliness too. (disconnect you battery before playing with this fuse - It's easy to open this fuse). When a power connection begins to corode it drops voltage across it. As the temp rises the resistance in this connection will rise making a bad situation worse. That may be why you notice it more with a hot engine. I suspect your are getting below some nominal voltage limits for your radio and possbly the fuel relay. Good luck.
cscottyr
Old Jun 29, 2004 | 10:22 AM
Rockledge's Avatar
Rockledge
I agree with cscottyr, you should focus on the charging system to fix the hard start issue. Especially look at the battery and alternator, and their connections.
The P0401 code is probably a result of a bad DPFE sensor and/or clogged EGR ports.
The P1143 code means your fuel vapor management system is blocked upor not working.
The problems evidenced by these codes can cause your engine to run poorly and inefficiently, and will result in your truck to failing an emissions test.
Try doing a search of this forum using the code numbers as your keywords, you will find some more information that way.
Old Jul 2, 2004 | 02:44 PM
gman39's Avatar
gman39
thanks for the informaition guys I will give it a try this weekend.
Old Jul 19, 2004 | 07:44 AM
gman39's Avatar
gman39
Ok, I finally purchased a new battery. While putting the battery into the truck I droped the wrench and it shorted across the battery terminals for a nanosecond. I hooked up the battery and now all i get is that clicking noise like the battery is dead. I can jump start the truck but it will not start with only the battery? Did I ruin the battery or could it be something else? Would the truck still start if I fried the starter relay? I dont think this had to do with the alternator because the battery was new. Also, when I try to strat the truck the dome light and the door open chime go off and stay off for a couple of seconds then come back on. I jumped it this morning and drove to work but when I got here the alarm would not set but the electric door locks worked.
Old Jul 19, 2004 | 08:13 PM
Ken00's Avatar
Ken00
Sounds like the battery is messed up to me.
tazbarj
Modular V10 (6.8l)
Apr 7, 2015 10:24 PM
Dave145
Aug 14, 2013 09:36 PM
broke-n
Electrical Systems/Wiring
Mar 12, 2011 05:12 PM
BEAVER
27
Dec 12, 2001 10:56 PM
