4x4 conversion
Old Jun 28, 2004 | 11:18 PM
Dalamatition's Avatar
Dalamatition
4x4 conversion
Has anyone here done a 4x4 conversion on their two wheel drive 87-96 F-series pickup? And are there 4x4 models that have the E40D tranny? I'm wondering if a transfer case can be bolted to the E40D. I was told by another F-series owner that it would be easy to do it because of the IFS design.
Old Jun 28, 2004 | 11:30 PM
felske's Avatar
felske
i have done the converstion. It was not that bad, it was kinda a bitch for me cause my duel exhasut got in the way. You cant just take a 2x4 tranny and bolt a tcase to it. The output shaft is different, you will have to get the piece that goes between the tcase and the tranny. Normaly it is just easier to get a used 4x4 trany.
You may also have to track down a different drive shaft. I just got mine shortened and welded. Only cost 20 bucks, so it was cheaper than getting a used drive shaft.
kyle
Old Jun 28, 2004 | 11:58 PM
Dalamatition
Oh cool. Thanks. A used 4x4 E40D should be right around $300-$500 right?
