Sponsored by: Innova
Is it safe?
Old Jun 28, 2004 | 08:08 PM
stoogesrule's Avatar
stoogesrule
Unhappy Is it safe?
Put in new cd player worked fine before install...installed everything back together...nothing....checked fuse panel...ok....Is it safe to run hot wire from battery to cd player? Seems like I checked everything...Dont have owner manual for it...1991 explorer. Any help? Thanks.
Old Jun 28, 2004 | 08:31 PM
triton_2002's Avatar
triton_2002
That's not a good idea. What do you mean the the cd player worked fine before the install? Did you have it in another vehicle and now it doesn't work in this one? Is this an aftermarket cd player? Did you check the fuses in the power wire and ignition controlled power wire for the cd player? Need more info to help you out better.
Old Jun 28, 2004 | 09:53 PM
Renegadesrun's Avatar
Renegadesrun
Its safe to run the yellow (constant in MOST cases) to the battery, in fact, on some decks it is required. The only wire i absolutely say you MUST run yourself in a aftermarket install is the ground. Always choose your own ground as far way from other items groundpoint as possible.
Often wiring harnesses will group grounds to a common point and aftermarket deck will pick up that noise.
Often these stock grounds fail, and it goes unnoticed until the deck is removed. At which time, the individual removes the antenna which takes away the only working ground.....and loses a deck.
Old Jun 28, 2004 | 09:58 PM
Renegadesrun
wtf is with this place and replies not showing......sorry for the double post.
Last edited by Renegadesrun; Jun 28, 2004 at 10:00 PM. Reason: because this forum has issues with replies
Old Jun 28, 2004 | 10:20 PM
Twisted Ranger's Avatar
Twisted Ranger
First thing to check are the 2 fuses for power. Yhere is a radio fuse inside (ignition power), and either a radio fuse under the hood or a cigarette fuse inside (12 volt constant for radio). If either are blown, no radio.
Old Jun 29, 2004 | 08:54 AM
stoogesrule
Talking thanks
Thanks for the help....I found the problem...working great...
boxcarracer955
Apr 11, 2015 08:55 PM
bigZ64
Feb 13, 2008 08:27 AM
THEBOOGIEMAN
Sep 13, 2006 08:07 AM
teederj2002
Dec 21, 2003 02:48 PM
martincsm
Jul 3, 2002 12:54 PM
